Here is what I think we should do. We add another member (one bit, no extra storage needed) to allow the filter to override the ownership decision made by dbfl_has_copy. We should also rename dbfl_has_copy to dbfl_is_owner to make this clearer. Then, instead of defining a dummy dtor, you can set pfl->is_owner = 1 and all is well. Like this:
diff --git a/modules/database/src/ioc/db/db_field_log.h b/modules/database/src/ioc/db/db_field_log.h
index e517d529f..68e725ed6 100644
--- a/modules/database/src/ioc/db/db_field_log.h
+++ b/modules/database/src/ioc/db/db_field_log.h
@@ -107,6 +107,7 @@ struct dbfl_ref {
typedef struct db_field_log {
unsigned int type:1; /* type (union) selector */
+ unsigned int is_owner:1; /* whether we own the data */
/* ctx is used for all types */
unsigned int ctx:1; /* context (operation type) */
/* the following are used for value and reference types */
@@ -131,8 +132,9 @@ typedef struct db_field_log {
* this case, making a copy is redundant, so we have no dtor. But conceptually
* the db_field_log still owns the (empty) data.
-#define dbfl_has_copy(p)\
- ((p) && ((p)->type==dbfl_type_val || (p)->u.r.dtor || (p)->no_elements==0))
+#define dbfl_is_owner(p)\
+ ((p) && ((p)->type==dbfl_type_val || (p)->u.r.dtor || (p)->no_elements==0\
+ || (p)->is_owner))
#define dbfl_pfield(p)\
((p)->type==dbfl_type_val ? &p->u.v.field : p->u.r.field)
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399414
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0.
- [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ben Franksen via Core-talk
<2021>
2025
2026
<2021>
2025
2026
