Dirk Zimoch has proposed merging ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0.
Commit message:
Add filter to read info fields
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399414
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0.
diff --git a/modules/database/src/std/filters/Makefile b/modules/database/src/std/filters/Makefile
index ee6a0ae..16e8171 100644
--- a/modules/database/src/std/filters/Makefile
+++ b/modules/database/src/std/filters/Makefile
@@ -16,6 +16,7 @@ dbRecStd_SRCS += dbnd.c
dbRecStd_SRCS += arr.c
dbRecStd_SRCS += sync.c
dbRecStd_SRCS += decimate.c
+dbRecStd_SRCS += info.c
HTMLS += filters.html
diff --git a/modules/database/src/std/filters/filters.dbd.pod b/modules/database/src/std/filters/filters.dbd.pod
index 27e356f..4503380 100644
--- a/modules/database/src/std/filters/filters.dbd.pod
+++ b/modules/database/src/std/filters/filters.dbd.pod
@@ -6,15 +6,17 @@ The following filters are available in this release:
=over
-=item * L<TimeStamp|/"TimeStamp Filter ts">
+=item * L<TimeStamp|/TimeStamp Filter "ts">
-=item * L<Deadband|/"Deadband Filter dbnd">
+=item * L<Deadband|/Deadband Filter "dbnd">
-=item * L<Array|/"Array Filter arr">
+=item * L<Array|/Array Filter "arr">
-=item * L<Synchronize|/"Synchronize Filter sync">
+=item * L<Synchronize|/Synchronize Filter "sync">
-=item * L<Decimation|/"Decimation Filter dec">
+=item * L<Decimation|/Decimation Filter "dec">
+=item * L<Info Field|/Info Field Filter "info">
=back
@@ -285,3 +287,35 @@ once every minute:
=cut
+registrar(infoInitialize)
+=head3 Info Field Filter C<"info">
+This filter gives access to the info fields of a record.
+=head4 Parameters
+=over
+=item Name C<"name"> or C<"n">
+The name of the info field.
+=item Long String Flag C<"longstr"> or C<"l">
+If this optional flag is C<"yes">, C<"on">, or C<1>, the info field is returned
+as an array of C<CHAR>.
+If it is C<"no">, C<"off">, or C<0>, the info field is returned as a C<STRING>,
+truncated to 40 characters if necessary.
+The default is C<"auto">, which will use C<STRING> for sufficiently short values
+and array of C<CHAR> for long values.
+=back
+=head4 Example
+ $ caget 'test:channel.{"info":{"name":"infofield"}}
+ $ caget -S 'test:channel.{"info":{"name":"infofield","l":"yes"}}
+=cut
diff --git a/modules/database/src/std/filters/info.c b/modules/database/src/std/filters/info.c
new file mode 100644
index 0000000..2ec6a38
--- /dev/null
+++ b/modules/database/src/std/filters/info.c
@@ -0,0 +1,151 @@
+* Copyright (c) 2021 Paul Scherrer Institute
+* SPDX-License-Identifier: EPICS
+* EPICS BASE is distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+ * Author: Dirk Zimoch <dirk.zimoch at psi.ch>
+#include <stdio.h>
+#include <string.h>
+#include "chfPlugin.h"
+#include "dbStaticLib.h"
+#include "dbAccessDefs.h"
+#include "dbExtractArray.h"
+#include "db_field_log.h"
+#include "dbLock.h"
+#include "epicsExit.h"
+#include "freeList.h"
+#include "epicsExport.h"
+typedef struct myStruct {
+ char name[50]; /* arbitrary size, we better had dynamic strings */
+ DBENTRY dbentry;
+ int longstr;
+} myStruct;
+static void *myStructFreeList;
+static const
+chfPluginEnumType longstrEnum[] = {{"no",0}, {"off",0}, {"yes",1}, {"on",1}, {"auto",2}, {NULL, 0}};
+static const chfPluginArgDef opts[] = {
+ chfString (myStruct, name, "name", 1, 0),
+ chfString (myStruct, name, "n", 1, 0),
+ chfEnum (myStruct, longstr, "longstr", 0, 1, longstrEnum),
+ chfEnum (myStruct, longstr, "l", 0, 1, longstrEnum),
+ chfPluginArgEnd
+static void * allocPvt(void)
+ myStruct *my = (myStruct*) freeListCalloc(myStructFreeList);
+ if (!my) return NULL;
+ my->longstr = 2;
+ return (void *) my;
+static void freePvt(void *pvt)
+ freeListFree(myStructFreeList, pvt);
+static db_field_log* filter(void* pvt, dbChannel *chan, db_field_log *pfl)
+ myStruct *my = (myStruct*) pvt;
+ if (pfl->type == dbfl_type_ref && pfl->u.r.dtor)
+ pfl->u.r.dtor(pfl);
+ pfl->type = dbfl_type_ref;
+ pfl->u.r.dtor = NULL;
+ pfl->u.r.field = (void*)dbGetInfoString(&my->dbentry);
+ if (my->longstr) {
+ pfl->field_size = 1;
+ pfl->field_type = DBF_CHAR;
+ pfl->no_elements = strlen((char*)pfl->u.r.field)+1;
+ } else {
+ pfl->field_size = MAX_STRING_SIZE;
+ pfl->field_type = DBF_STRING;
+ pfl->no_elements = 1;
+ return pfl;
+static long channel_open(dbChannel *chan, void *pvt)
+ DBENTRY* pdbe = &my->dbentry;
+ int status;
+ dbInitEntryFromAddr(&chan->addr, pdbe);
+ for (status = dbFirstInfo(pdbe); !status; status = dbNextInfo(pdbe))
+ if (strcmp(dbGetInfoName(pdbe), my->name) == 0)
+ return 0;
+ return -1;
+static void channelRegisterPre(dbChannel *chan, void *pvt,
+ chPostEventFunc **cb_out, void **arg_out, db_field_log *pfl)
+ size_t len = strlen(dbGetInfoString(&my->dbentry)) + 1;
+ if (my->longstr == 2) {
+ my->longstr = len > MAX_STRING_SIZE;
+ pfl->no_elements = len;
+ } else {
+ *cb_out = filter;
+ *arg_out = pvt;
+static void channel_report(dbChannel *chan, void *pvt, int level,
+ const unsigned short indent)
+ printf("%*sInfo: name=%s\n", indent, "",
+ my->name);
+static chfPluginIf pif = {
+ allocPvt,
+ freePvt,
+ NULL, /* parse_error, */
+ NULL, /* parse_ok, */
+ channel_open,
+ channelRegisterPre,
+ NULL, /* channelRegisterPost, */
+ channel_report,
+ NULL /* channel_close */
+static void infoShutdown(void* ignore)
+ if(myStructFreeList)
+ freeListCleanup(myStructFreeList);
+ myStructFreeList = NULL;
+static void infoInitialize(void)
+ if (!myStructFreeList)
+ freeListInitPvt(&myStructFreeList, sizeof(myStruct), 64);
+ chfPluginRegister("info", &pif, opts);
+ epicsAtExit(infoShutdown, NULL);
+epicsExportRegistrar(infoInitialize);
- Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ben Franksen via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 mdavidsaver via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ralph Lange via Core-talk
- Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Andrew Johnson via Core-talk
epics-pva2pva-linux32 - Build # 215 - Fixed! APS Jenkins via Core-talk
<2021>
2025
2026
Re: [EXTERNAL] Re: errlog.h Michael Davidsaver via Core-talk
<2021>
2025
2026
