Even though it makes no sense, it is totally leagal to do so. The two lines normally cost nothing because in the typical case dtor is NULL. Actually type is typically not even ref. But they prevent a memory leak in case someone does stack info ontop of another filter.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399414
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0.
- [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Build failed: epics-base base-integration-656 AppVeyor via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
<2021>
2025
2026
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ben Franksen via Core-talk
<2021>
2025
2026
