2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: mp+399414 at code.launchpad.net
Date: Wed, 10 Mar 2021 21:33:26 -0000
I don't think we disagree. I am fine with your definition "is_owner==!must_lock". But whether or not to lock (dbScanLock) is not the only question relevant here.
Immutable data does not have an owner: there is no need for any locking. Nevertheless (in the absence of garbage collection or ref counting) we must assign responsibility for deallocating the memory (unless the data remains life forever). This is signalled by a non-NULL dtor.
The other question is who has the relevant meta data? Again, for mutable data this is clearly the owner. For immutable data it could be the record or the field_log.
My refactor conflated all three notions: presence of a dtor == db_field_log is owner == db_field_log has the meta data. This is okay for mutable data but not for immutable.
The problem at hand, filters that allow to access info items, has these features: the data is immutable, so no owner; it has infinite life time, so there is no dtor; yet the meta data is held by the field_log, not the record.
This means we need another "degree of freedom": at least one extra bit, perhaps two. The design question is: precisely what meaning shall these bits have?
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399414
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0.
[Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 mdavidsaver via Core-talk
Next: Build failed: epics-base base-alarm-msg-654 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Next: Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
ANJ, 11 Mar 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
