> What happens when the record owns a reference and we lock it and then access the data can be called "borrowing". This is a temporary state and not a property of the db_field_log.
By "borrowed" I was meaning that a db_field_log which references a buffer which may only be accessed with a dbScanLock() of the associated record. Indeed struct db_field_log does not current encode this associate fully.
I think that you and I (Ben) probably have the same idea with only a sign flip in the name. Would you agree that "is_owner==!must_lock"? In your mind, does "is_owner" have a wider meaning than record locking? eg. does "is_owner" imply anything about the presence or absence of a dtor?
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/399414
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0.
- [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Dirk Zimoch via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 mdavidsaver via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:FilterForInfoFields into epics-base:7.0 Ben Franksen via Core-talk
<2021>
2025
2026
<2021>
2025
2026
