Update: Since I want things to also work with older Base releases, I added a workaround on Windows, allowing the Windows notation of %varname% to read the value from the environment post iocShell inside my driver code. Straightforward and good enough. But: I still think the current macLib policy of keeping escapes at the top level and resolving them at any other use is not right. Here's an example. Assume I have a driver with an iocShell configuration function that takes a path as its parameter and I want to use backslashes as a path separator. When using the configuration function directly, I need to escape the backslashes to get them into the driver. So far, so expected.
If I want to plainly do the same thing through an environment variable, guess how many backslashes it takes? Eight!
IMHO, this is insane. Cheers, ~Ralph
| ANJ, 18 Apr 2021 |
Home
News
About
Talk
Base
Modules
Extensions
