Hi Ben,
I have applied your patch. Unfortunately it does not help with my problem. The out of bounds access you fixed is only a
read access, unlikely to cause memory corruption.
After adding debug output, I see that the devIocStats function scan_time() runs several times without problems but then
suddenly crashes in scanIoRequest.
I tested other drivers using I/O Intr scanning and got the same problem. So it seems devIocStats was innocent.
But I see another strange thing. Just after the iocInit message, I noticed "Warning: callbackInit called again before
callbackCleanup". Looks like maybe something is messed up with the callbacks threads used by I/O Intr. Investigating
that now...
Dirk
On Tue, 2021-06-08 at 10:43 +0200, Ben Franksen via Core-talk wrote:
> Am 07.06.21 um 14:53 schrieb Zimoch Dirk (PSI) via Core-talk:
> > Further investigation showed that the bug is somehow related to devIocStats (not loading it does not trigger the
> > problem).
> > The problem seems to be caused by memory corruption. When printing spin->locked (which should be 0 or 1), I get
> > 1919513701 = 0x7269746.
> > Maybe one out our modifications to devIocStats was buggy.
> The fix I have just now made a PR for
> (https://github.com/epics-modules/iocStats/pull/40) may be related to this.
> Cheers
> Ben
- Re: Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
- Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
- Re: Deadlock on VxWorks 6.7 Michael Davidsaver via Core-talk
- AW: Deadlock on VxWorks 6.7 Zimoch Dirk (PSI) via Core-talk
- Re: Deadlock on VxWorks 6.7 Ben Franksen via Core-talk
<2021>
2025
2026
<2021>
2025
2026
