Hi Mark,
My problem is now completely solved. The solution is not to build with the windows-x64 architecture, in spite of the fact the ezcaIDL is building a DLL. One needs to use the windows-x64-static architecture, but specify SHARED_LIBRARIES=YES in the Makefile.
The resulting DLL is completely self-contained, no dependency on base, ezca, or EzscaScan.
You may be able to modify the Makefiles to have them build a LOADABLE_LIBRARY instead of a SHARED_LIBRARY since that’s what’s needed; on Windows that should still create a DLL even when SHARED_LIBRARIES=NO. That target type may not have existed in 2007
when the Makefile was last worked on.
I am going to make pull requests for ezca, EzcaScan, and ezcaIDL. Their Makefiles date from before when there were separate Windows architectures for dynamic builds (windows-x64) and static builds (windows-x64-static). The .def files are no
longer needed, and I will fix compiler warnings.
There was a PR against ezca recently to convert it to build stand-alone instead of in an extensions tree, but the branch still needs a few modifications IMO and those three modules
should probably all be converted together if it’s going to happen. Nobody is really managing the ezca extensions modules any more – I converted their CVS history to Git several years ago, but I don’t have any customers that I know of so have no incentive to
do anything with them myself. Not sure whether BCDA are still building these or not.
- Andrew
Complexity comes for free, simplicity you have to work for.
- RE: Problem building ezcaIDL on Windows Mark Rivers via Core-talk
- Problem building ezcaIDL on Windows Mark Rivers via Core-talk
- Re: Problem building ezcaIDL on Windows Michael Davidsaver via Core-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 11 Jun 2021 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
