2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: RE: Building base 7.0.6 with parallel make fails on windows-x64
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: "'Johnson, Andrew N.'" <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 20 Sep 2021 20:42:12 +0000
Hi Andrew,
Ø  How repeatable is the failure?
I seem to have repeatable problems, but they are not exactly what I saw before.
This is the output when I do “make clean uninstall” and then “make –sj8”, putting the output in file build3.txt.
H:\epics-devel\base-7.0.6>make -sj clean uninstall
H:\epics-devel\base-7.0.6>make -sj8 >  build3.txt
toolchain.c
'..' is not recognized as an internal or external command,
operable program or batch file.
I have attached the output file from that build, build3.txt.  I don’t see any errors.  However, it did not build the pvAccess, pvDatabase, etc. modules.  These are the only DLLs in bin\windows-x64.
H:\epics-devel\base-7.0.6>dir bin\windows-x64\*.dll
Volume in drive H is local_rw
Volume Serial Number is 6DDD-530A
Directory of H:\epics-devel\base-7.0.6\bin\windows-x64
09/20/2021  03:15 PM           438,784 Com.dll
09/20/2021  03:18 PM           317,440 ca.dll
09/20/2021  03:21 PM           549,888 dbCore.dll
09/20/2021  03:24 PM           307,200 dbRecStd.dll
               4 File(s)      1,613,312 bytes
               0 Dir(s)  700,124,401,664 bytes free
That does not seem correct, there should be many more DLLs.
I then just run “make –sj” again without cleaning first, putting the output in build4.txt
H:\epics-devel\base-7.0.6>make -sj8 >  build4.txt
There was no command line output.  The build did not create the missing DLLs.  I have attached build4.txt as well.
Sent: Wednesday, September 15, 2021 5:45 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Subject: Re: Building base 7.0.6 with parallel make fails on windows-x64
Hi Mark,
On Sep 11, 2021, at 9:02 AM, Mark Rivers via Core-talk <core-talk at aps.anl.gov> wrote:
I tried to build base 7.0.6 on windows-x64 using “make –sj8” on an 8-core machine.  It failed as follows:
softIoc_registerRecordDeviceDriver.cpp
softMain.cpp
   Creating library dbRecStd.lib and object dbRecStd.exp
Generating code
Finished generating code
Generating code
The above files and dbCommon.dbd are built within modules/database/src.
dbdExpand.pl: Can't find file 'dbCommon.dbd'
  while reading 'base.dbd' to create 'recTestIoc.dbd'
dbdExpand.pl: Exiting due to errors
make[5]: *** [../../../../../../configure/RULES.Db:403: ../O.Common/recTestIoc.dbd] Error 2
make[5]: *** Waiting for unfinished jobs....
make[4]: *** [../../../../../configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[3]: *** [../../../configure/RULES_DIRS:85: std/rec.install] Error 2
make[3]: *** Waiting for unfinished jobs....
The recTestIoc.dbd file is created within modules/database/test/std/rec which is built as a subdirectory of modules/database/test. There is a hard dependency specified in modules/database/Makefile so it isn’t supposed to be possible to start building in the test directory until the src directory has finished building:
DIRS += src
DIRS += test
test_DEPEND_DIRS = src
Thus I’m having difficulty imagining how that failure can occur (I’m not saying it couldn’t, I just don’t see how at the moment). How repeatable is the failure?
Running make –sj8 again appeared to work although it started with this message:
asTestLib.c
dbHeaderTest.c
arrayOpTest.c
Those .c files are compiled in the modules/database/test/std/rec directory, which makes sense given the failure above. I’ll see if I can work out what the ‘..’ program might have been in case it provides more clues.
- Andrew
Complexity comes for free, simplicity you have to work for.
ccl.c
dfa.c
ecs.c
gen.c
misc.c
nfa.c
sym.c
tblcmp.c
error.c
closure.c
lalr.c
lr0.c
antelope.c
mkpar.c
output.c
h:\epics-devel\base-7.0.6\modules\libcom\src\yacc\lr0.c(177): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\yacc\lr0.c(305): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\yacc\output.c(1011): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\yacc\antelope.c(241): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
reader.c
skeleton.c
symtab.c
verbose.c
warshall.c
h:\epics-devel\base-7.0.6\modules\libcom\src\yacc\reader.c(1523): warning C4267: '+=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\yacc\reader.c(1761): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
Generating code
parse.c
scan.l(935): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
scan.l(180): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
scan.l(240): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
scan.l(269): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
scan.l(271): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
scan.l(326): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
scan.l(347): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
scan.l(363): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
scan.l(379): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
scan.l(382): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
scan.l(385): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
scan.l(513): warning C4244: 'initializing': conversion from '__int64' to 'int', possible loss of data
scan.l(649): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
scan.l(805): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
Generating code
asLib.c
asTrapWrite.c
bucketLib.c
postfix.c
calcPerform.c
cvtFast.c
resourceLib.cpp
h:\epics-devel\base-7.0.6\modules\libcom\src\bucketlib\bucketlib.c(180): warning C4267: '=': conversion from 'size_t' to 'BUCKETID', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\bucketlib\bucketlib.c(183): warning C4267: '=': conversion from 'size_t' to 'BUCKETID', possible loss of data
epicsSingletonMutex.cpp
dbmf.c
h:\epics-devel\base-7.0.6\modules\libcom\src\cvtfast\cvtfast.c(312): warning C4244: '=': conversion from 'epicsUInt64' to 'char', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\cvtfast\cvtfast.c(334): warning C4244: '=': conversion from 'epicsUInt64' to 'char', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\cvtfast\cvtfast.c(374): warning C4146: unary minus operator applied to unsigned type, result still unsigned
h:\epics-devel\base-7.0.6\modules\libcom\src\cvtfast\cvtfast.c(436): warning C4146: unary minus operator applied to unsigned type, result still unsigned
h:\epics-devel\base-7.0.6\modules\libcom\src\cvtfast\cvtfast.c(473): warning C4146: unary minus operator applied to unsigned type, result still unsigned
ellLib.c
ellSort.c
envSubr.c
envData.c
h:\epics-devel\base-7.0.6\modules\libcom\src\elllib\ellsort.c(58): warning C4267: 'function': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\elllib\ellsort.c(59): warning C4267: 'function': conversion from 'size_t' to 'int', possible loss of data
errlog.c
errSymLib.c
errSymTbl.c
fdmgr.cpp
fdManager.cpp
h:\epics-devel\base-7.0.6\modules\libcom\src\error\errlog.c(101): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\error\errlog.c(475): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
freeListLib.c
h:\epics-devel\base-7.0.6\modules\libcom\src\as\aslibroutines.c(218): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\as\aslibroutines.c(375): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\as\aslibroutines.c(400): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
../as/asLib_lex.l(330): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
../as/asLib_lex.l(103): warning C4244: 'initializing': conversion from '__int64' to 'int', possible loss of data
../as/asLib_lex.l(239): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
../as/asLib_lex.l(398): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
gpHashLib.c
h:\epics-devel\base-7.0.6\modules\libcom\src\cxxtemplates\resourcelib.h(1107): warning C4267: 'initializing': conversion from 'size_t' to 'unsigned int', possible loss of data
iocsh.cpp
initHooks.c
registry.c
libComRegister.c
h:\epics-devel\base-7.0.6\modules\libcom\src\freelist\freelistlib.c(49): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
iocLog.c
logClient.c
h:\epics-devel\base-7.0.6\modules\libcom\src\iocsh\iocsh.cpp(469): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
macCore.c
macEnv.c
h:\epics-devel\base-7.0.6\modules\libcom\src\fdmgr\fdmanager.cpp(115): warning C4244: '=': conversion from 'time_t' to 'long', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\fdmgr\fdmanager.cpp(121): warning C4244: 'argument': conversion from 'SOCKET' to 'int', possible loss of data
macUtil.c
h:\epics-devel\base-7.0.6\modules\libcom\src\maclib\maccore.c(219): warning C4244: '=': conversion from '__int64' to 'long', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\maclib\maccore.c(295): warning C4267: 'return': conversion from 'size_t' to 'long', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\maclib\maccore.c(351): warning C4267: '=': conversion from 'size_t' to 'long', possible loss of data
alarmString.c
aToIPAddr.c
adjustment.c
cantProceed.c
epicsExit.c
epicsConvert.c
h:\epics-devel\base-7.0.6\modules\libcom\src\iocsh\libcomregister.c(357): warning C4312: 'type cast': conversion from 'unsigned long' to 'epicsThreadId' of greater size
h:\epics-devel\base-7.0.6\modules\libcom\src\iocsh\libcomregister.c(433): warning C4312: 'type cast': conversion from 'unsigned long' to 'epicsThreadId' of greater size
h:\epics-devel\base-7.0.6\modules\libcom\src\log\logclient.c(173): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\log\logclient.c(566): warning C4267: 'initializing': conversion from 'size_t' to 'unsigned int', possible loss of data
epicsStdlib.c
epicsString.c
truncateFile.c
ipAddrToAsciiAsynchronous.cpp
h:\epics-devel\base-7.0.6\modules\libcom\src\misc\epicsstring.c(52): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\misc\epicsstring.c(123): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
epicsUnitTest.c
epicsThread.cpp
epicsMutex.cpp
epicsEvent.cpp
epicsTime.cpp
epicsMessageQueue.cpp
epicsMath.cpp
epicsAtomicOSD.cpp
epicsGeneralTime.c
osiClockTime.c
osdSockAddrReuse.cpp
osdSock.c
osdSockUnsentCount.c
osiSock.c
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\epicsgeneraltime.c(222): warning C4244: '=': conversion from 'epicsUInt64' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\epicstime.cpp(426): warning C4244: '=': conversion from 'time_t' to 'long', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\epicstime.cpp(655): warning C4267: '=': conversion from 'size_t' to 'unsigned long', possible loss of data
systemCallIntMech.cpp
epicsSocketConvertErrnoToString.cpp
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\os\win32\osdsock.c(125): warning C4244: 'return': conversion from 'SOCKET' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\os\win32\osdsock.c(156): warning C4267: 'return': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\os\win32\osdsock.c(152): warning C4996: 'gethostbyaddr': Use getnameinfo() or GetNameInfoW() instead or define _WINSOCK_DEPRECATED_NO_WARNINGS to disable deprecated API warnings
c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\winsock2.h(2197): note: see declaration of 'gethostbyaddr'
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\os\win32\osdsock.c(169): warning C4996: 'gethostbyname': Use getaddrinfo() or GetAddrInfoW() instead or define _WINSOCK_DEPRECATED_NO_WARNINGS to disable deprecated API warnings
c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\winsock2.h(2219): note: see declaration of 'gethostbyname'
osdAssert.c
osdFindSymbol.c
osdInterrupt.c
osdPoolStatus.c
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\osisock.c(70): warning C4267: 'initializing': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\osisock.c(123): warning C4267: 'initializing': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\osisock.c(177): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
osdSignal.cpp
osdEnv.c
epicsReadline.c
epicsTempFile.c
epicsStdio.c
osdStdio.c
osdThread.c
osdThreadExtra.c
osdThreadHooks.c
osdMutex.c
osdSpin.c
osdEvent.c
osdTime.cpp
osdMonotonic.c
osdProcess.c
osdNetIntf.c
osdMessageQueue.cpp
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\os\win32\osdthread.c(490): warning C4312: 'type cast': conversion from 'unsigned int' to 'void *' of greater size
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\os\win32\osdmutex.c(73): warning C4996: 'GetVersionExA': was declared deprecated
c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\sysinfoapi.h(378): note: see declaration of 'GetVersionExA'
osdgetexec.c
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\os\default\osdmessagequeue.cpp(409): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\os\default\osdmessagequeue.cpp(411): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\os\win32\osdmonotonic.c(54): warning C4244: '=': conversion from 'LONGLONG' to 'double', possible loss of data
devLibVME.c
devLibVMEOSD.c
epicsStackTrace.c
osdBackTrace.cpp
osdFindAddr.c
poolJob.c
threadPool.c
epicsRingPointer.cpp
epicsRingBytes.c
h:\epics-devel\base-7.0.6\modules\libcom\src\osi\os\win32\osdgetexec.c(29): warning C4267: 'function': conversion from 'size_t' to 'DWORD', possible loss of data
taskwd.c
epicsTimer.cpp
h:\epics-devel\base-7.0.6\modules\libcom\src\pool\threadpool.c(344): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
timer.cpp
timerQueue.cpp
timerQueueActive.cpp
timerQueueActiveMgr.cpp
timerQueuePassive.cpp
yajl.c
yajl_alloc.c
yajl_buf.c
yajl_encode.c
yajl_gen.c
yajl_lex.c
yajl_parser.c
epicsGetopt.c
setThreadName.cpp
forceBadAllocException.cpp
iocLogServer.c
Microsoft (R) Windows (R) Resource Compiler Version 10.0.10011.16384
Copyright (C) Microsoft Corporation.  All rights reserved.
h:\epics-devel\base-7.0.6\modules\libcom\src\log\ioclogserver.c(414): warning C4244: 'function': conversion from 'SOCKET' to 'int', possible loss of data
   Creating library Com.lib and object Com.exp
Generating code
Generating code
epicsUnitTestTest.c
epicsTypesTest.c
epicsInlineTest1.c
epicsInlineTest2.c
epicsInlineTest3.cpp
epicsInlineTest4.cpp
epicsCalcTest.cpp
epicsAlgorithmTest.cpp
epicsMathTest.c
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(73): warning C4800: 'int': forcing value to bool 'true' or 'false' (performance warning)
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(553): warning C4806: '!=': unsafe operation: no value of type 'bool' promoted to type 'int' can equal the given constant
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(573): warning C4806: '!=': unsafe operation: no value of type 'bool' promoted to type 'int' can equal the given constant
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(674): warning C4804: '<': unsafe use of type 'bool' in operation
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(697): warning C4804: '<=': unsafe use of type 'bool' in operation
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(742): warning C4804: '>': unsafe use of type 'bool' in operation
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(762): warning C4804: '>=': unsafe use of type 'bool' in operation
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(872): warning C4554: '|': check operator precedence for possible error; use parentheses to clarify precedence
epicsMMIOTest.c
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(873): warning C4554: '|': check operator precedence for possible error; use parentheses to clarify precedence
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(874): warning C4554: '^': check operator precedence for possible error; use parentheses to clarify precedence
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(884): warning C4554: '&': check operator precedence for possible error; use parentheses to clarify precedence
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(885): warning C4554: '&': check operator precedence for possible error; use parentheses to clarify precedence
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(886): warning C4804: '<<': unsafe use of type 'bool' in operation
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(887): warning C4804: '>>': unsafe use of type 'bool' in operation
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(888): warning C4804: '>>': unsafe use of type 'bool' in operation
epicsEllTest.c
epicsEnvTest.c
epicsEnvUnsetTest.c
epicsErrlogTest.c
epicsStdioTest.c
epicsStdlibTest.c
h:\epics-devel\base-7.0.6\modules\libcom\test\epicselltest.c(244): warning C4267: 'function': conversion from 'size_t' to 'int', possible loss of data
epicsSockResolveTest.c
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsstdiotest.c(50): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsstdiotest.c(61): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsstdiotest.c(110): warning C4267: 'function': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsstdiotest.c(118): warning C4267: 'function': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsstdiotest.c(124): warning C4267: 'function': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsstdlibtest.c(274): warning C4146: unary minus operator applied to unsigned type, result still unsigned
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsstdlibtest.c(316): warning C4146: unary minus operator applied to unsigned type, result still unsigned
epicsStringTest.c
epicsTimeTest.cpp
epicsTimeZoneTest.c
epicsThreadTest.cpp
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsstringtest.c(224): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsstringtest.c(226): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsstringtest.c(228): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of dataepicsThreadClassTest.cpp
epicsThreadOnceTest.c
epicsThreadPriorityTest.cpp
h:\epics-devel\base-7.0.6\modules\libcom\test\epicserrlogtest.c(373): warning C4267: 'function': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\epicserrlogtest.c(487): warning C4244: 'function': conversion from 'SOCKET' to 'int', possible loss of data
epicsThreadPrivateTest.cpp
epicsThreadHooksTest.c
epicsThreadPoolTest.c
initHookTest.c
epicsExitTest.c
epicsTimerTest.cpp
ringPointerTest.c
epicsEventTest.cpp
ringBytesTest.c
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsthreadpooltest.c(104): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsthreadpooltest.c(112): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsthreadpooltest.c(113): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
epicsMutexTest.cpp
epicsSpinTest.c
epicsAtomicTest.cpp
macDefExpandTest.c
cvtFastTest.c
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(239): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(240): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(241): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(242): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(243): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(244): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(245): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(246): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(247): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(248): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(249): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(250): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(251): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(252): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(253): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(254): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(255): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(256): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(266): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(267): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(268): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(269): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(300): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(301): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(302): warning C4305: 'function': truncation from 'double' to 'float'
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfasttest.c(303): warning C4305: 'function': truncation from 'double' to 'float'
macLibTest.c
aslibtest.c
taskwdTest.c
blockingSockTest.cpp
h:\epics-devel\base-7.0.6\modules\libcom\test\maclibtest.c(29): warning C4267: 'initializing': conversion from 'size_t' to 'long', possible loss of data
epicsMessageQueueTest.cpp
osiSockTest.c
ipAddrToAsciiTest.cpp
epicsStackTraceTest.c
testexecname.c
iocshTest.cpp
epicsLoadTest.cpp
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsstacktracetest.c(97): warning C4267: '+=': conversion from 'size_t' to 'int', possible loss of data
epicsThreadPerform.cpp
epicsMaxThreads.c
buckTest.c
epicsAtomicPerform.cpp
cvtFastPerform.cpp
h:\epics-devel\base-7.0.6\modules\libcom\test\bucktest.c(51): warning C4018: '<': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\libcom\test\epicsatomicperform.cpp(51): warning C4267: 'initializing': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfastperform.cpp(99): warning C4244: 'argument': conversion from 'double' to 'float', possible loss of data
h:\epics-devel\base-7.0.6\modules\libcom\test\cvtfastperform.cpp(118): warning C4244: 'argument': conversion from 'double' to 'float', possible loss of data
Generating code
Generating code
Generating code
Generating code
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(94) : warning C4723: potential divide by 0
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(56) : warning C4723: potential divide by 0
h:\epics-devel\base-7.0.6\modules\libcom\test\epicscalctest.cpp(30) : warning C4723: potential divide by 0
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
cac.cpp
cacChannel.cpp
cacChannelNotify.cpp
cacReadNotify.cpp
cacContextNotify.cpp
cacWriteNotify.cpp
cacStateNotify.cpp
access.cpp
iocinf.cpp
convert.cpp
test_event.cpp
repeater.cpp
searchTimer.cpp
disconnectGovernorTimer.cpp
h:\epics-devel\base-7.0.6\modules\ca\src\client\access.cpp(312): warning C4244: 'argument': conversion from 'SOCKET' to 'int', possible loss of data
repeaterSubscribeTimer.cpp
h:\epics-devel\base-7.0.6\modules\ca\src\client\repeater.cpp(495): warning C4800: 'int': forcing value to bool 'true' or 'false' (performance warning)
baseNMIU.cpp
nciu.cpp
netiiu.cpp
udpiiu.cpp
tcpiiu.cpp
noopiiu.cpp
netReadNotifyIO.cpp
netWriteNotifyIO.cpp
netSubscription.cpp
h:\epics-devel\base-7.0.6\modules\ca\src\client\netiiu.cpp(99): warning C4267: 'initializing': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\client\tcpiiu.cpp(1061): warning C4477: 'printf' : format string '%d' requires an argument of type 'int', but variadic argument 1 has type 'const SOCKET'
h:\epics-devel\base-7.0.6\modules\ca\src\client\tcpiiu.cpp(1061): note: consider using '%lld' in the format string
h:\epics-devel\base-7.0.6\modules\ca\src\client\tcpiiu.cpp(1061): note: consider using '%Id' in the format string
h:\epics-devel\base-7.0.6\modules\ca\src\client\tcpiiu.cpp(1061): note: consider using '%I64d' in the format string
h:\epics-devel\base-7.0.6\modules\ca\src\client\tcpiiu.cpp(1301): warning C4267: 'initializing': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\client\tcpiiu.cpp(1331): warning C4267: 'initializing': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\client\tcpiiu.cpp(2177): warning C4267: 'argument': conversion from 'size_t' to 'unsigned int', possible loss of data
tcpSendWatchdog.cpp
tcpRecvWatchdog.cpp
bhe.cpp
ca_client_context.cpp
oldChannelNotify.cpp
oldSubscription.cpp
getCopy.cpp
getCallback.cpp
putCallback.cpp
syncgrp.cpp
h:\epics-devel\base-7.0.6\modules\ca\src\client\ca_client_context.cpp(169): warning C4244: 'argument': conversion from 'SOCKET' to 'int', possible loss of data
CASG.cpp
syncGroupNotify.cpp
syncGroupReadNotify.cpp
syncGroupWriteNotify.cpp
localHostName.cpp
comQueRecv.cpp
comQueSend.cpp
comBuf.cpp
hostNameCache.cpp
msgForMultiplyDefinedPV.cpp
h:\epics-devel\base-7.0.6\modules\ca\src\client\localhostname.cpp(41): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
ca_test_main.c
ca_test.c
h:\epics-devel\base-7.0.6\modules\ca\src\client\comquesend.cpp(334): warning C4267: '=': conversion from 'size_t' to 'ca_uint32_t', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\client\hostnamecache.cpp(38): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\client\hostnamecache.cpp(65): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
caRepeater.cpp
catimeMain.c
catime.c
acctstMain.c
acctst.c
caConnTestMain.cpp
caConnTest.cpp
casw.cpp
caEventRateMain.cpp
caEventRate.cpp
h:\epics-devel\base-7.0.6\modules\ca\src\client\catime.c(577): warning C4267: '+=': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\client\catime.c(589): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\client\casw.cpp(303): warning C4267: '-=': conversion from 'size_t' to 'unsigned int', possible loss of data
   Creating library ca.lib and object ca.exp
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
tool_lib.c
caget.c
cainfo.c
camonitor.c
caput.c
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(141): warning C4244: '=': conversion from 'double' to 'dbr_long_t', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(143): warning C4244: '=': conversion from 'double' to 'dbr_long_t', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(152): warning C4244: '=': conversion from 'dbr_double_t' to 'dbr_long_t', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(154): warning C4244: '=': conversion from 'dbr_double_t' to 'dbr_long_t', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\caput.c(212): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\caput.c(415): warning C4267: '+=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(532): warning C4267: '=': conversion from 'size_t' to 'unsigned long', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\caget.c(276): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of datah:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(532): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\caget.c(322): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of datah:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(532): warning C4018: '<': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(535): warning C4267: '=': conversion from 'size_t' to 'unsigned long', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(535): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(535): warning C4018: '<': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(538): warning C4267: '=': conversion from 'size_t' to 'unsigned long', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(538): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(538): warning C4018: '<': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(541): warning C4267: '=': conversion from 'size_t' to 'unsigned long', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(541): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(541): warning C4018: '<': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(544): warning C4267: '=': conversion from 'size_t' to 'unsigned long', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(544): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(544): warning C4018: '<': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(547): warning C4267: '=': conversion from 'size_t' to 'unsigned long', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(547): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(547): warning C4018: '<': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(550): warning C4267: '=': conversion from 'size_t' to 'unsigned long', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(550): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\ca\src\tools\tool_lib.c(550): warning C4018: '<': signed/unsigned mismatch
Generating code
Generating code
Generating code
Generating code
makeBpt.c
asDbLib.c
asCa.c
asIocRegister.c
dbLock.c
dbAccess.c
dbBkpt.c
dbChannel.c
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dblock.c(87): warning C4267: '=': conversion from 'size_t' to 'unsigned long', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbchannel.c(119): warning C4244: 'function': conversion from '__int64' to 'long', possible loss of data
dbConstLink.c
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbaccess.c(859): warning C4267: '=': conversion from 'size_t' to 'long', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbaccess.c(893): warning C4267: '=': conversion from 'size_t' to 'long', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbaccess.c(1043): warning C4267: '=': conversion from 'size_t' to 'long', possible loss of data
dbConvert.c
dbConvertJSON.c
dbDbLink.c
dbFastLinkConv.c
dbExtractArray.c
dbJLink.c
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconstlink.c(97): warning C4244: '=': conversion from 'double' to 'epicsUInt32', possible loss of data
dbLink.c
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvertjson.c(167): warning C4244: '=': conversion from 'long' to 'short', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(306): warning C4244: '=': conversion from 'epicsFloat64' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvertjson.c(238): warning C4244: '=': conversion from '__int64' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(745): warning C4244: 'function': conversion from 'long' to 'epicsUInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(750): warning C4244: 'function': conversion from 'long' to 'epicsUInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(786): warning C4244: 'function': conversion from 'long' to 'epicsUInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(791): warning C4244: 'function': conversion from 'long' to 'epicsUInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(1056): warning C4244: '=': conversion from 'epicsFloat64' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(1531): warning C4244: 'function': conversion from 'const epicsUInt64' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(1536): warning C4244: 'function': conversion from 'const epicsUInt64' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(1573): warning C4244: 'function': conversion from 'long' to 'epicsUInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(1578): warning C4244: 'function': conversion from 'long' to 'epicsUInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(1615): warning C4244: 'function': conversion from 'long' to 'epicsUInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbconvert.c(1620): warning C4244: 'function': conversion from 'long' to 'epicsUInt16', possible loss of datah:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(192): warning C4244: '=': conversion from 'double' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(881): warning C4244: '=': conversion from 'epicsInt64' to 'epicsInt8', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(888): warning C4244: '=': conversion from 'epicsInt64' to 'epicsUInt8', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(895): warning C4244: '=': conversion from 'epicsInt64' to 'epicsInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(902): warning C4244: '=': conversion from 'epicsInt64' to 'epicsUInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(909): warning C4244: '=': conversion from 'epicsInt64' to 'epicsInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(916): warning C4244: '=': conversion from 'epicsInt64' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(937): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(944): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(951): warning C4244: '=': conversion from 'epicsInt64' to 'epicsEnum16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(965): warning C4244: '=': conversion from 'epicsUInt64' to 'epicsInt8', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(972): warning C4244: '=': conversion from 'epicsUInt64' to 'epicsUInt8', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(979): warning C4244: '=': conversion from 'epicsUInt64' to 'epicsInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(986): warning C4244: '=': conversion from 'epicsUInt64' to 'epicsUInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(993): warning C4244: '=': conversion from 'epicsUInt64' to 'epicsInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(1000): warning C4244: '=': conversion from 'epicsUInt64' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(1021): warning C4244: '=': conversion from 'epicsUInt64' to 'epicsFloat32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(1028): warning C4244: '=': conversion from 'epicsUInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(1035): warning C4244: '=': conversion from 'epicsUInt64' to 'epicsEnum16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(1102): warning C4244: '=': conversion from 'epicsFloat32' to 'epicsInt64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(1109): warning C4244: '=': conversion from 'epicsFloat32' to 'epicsUInt64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(1183): warning C4244: '=': conversion from 'epicsFloat64' to 'epicsInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(1190): warning C4244: '=': conversion from 'epicsFloat64' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(1197): warning C4244: '=': conversion from 'epicsFloat64' to 'epicsInt64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbfastlinkconv.c(1204): warning C4244: '=': conversion from 'epicsFloat64' to 'epicsUInt64', possible loss of data
dbNotify.c
dbScan.c
dbEvent.c
dbTest.c
db_access.c
db_test.c
recGbl.c
callback.c
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbtest.c(858): warning C4018: '<': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbtest.c(998): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
dbCa.c
dbCaTest.c
cvtBpt.c
dbContext.cpp
dbChannelIO.cpp
dbSubscriptionIO.cpp
dbPutNotifyBlocker.cpp
dbContextReadNotifyCache.cpp
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbca.c(522): warning C4018: '>': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbca.c(893): warning C4018: '<=': signed/unsigned mismatch
dbIocRegister.c
chfPlugin.c
dbState.c
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbchannelnoop.h(83): warning C4138: '*/' found outside of comment
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbchannelnoop.h(36): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbcontext.cpp(75): warning C4800: 'int': forcing value to bool 'true' or 'false' (performance warning)
dbUnitTest.c
dbServer.c
dbStaticLib.c
dbYacc.c
dbPvdLib.c
dbStaticRun.c
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbunittest.c(148): warning C4244: '=': conversion from 'double' to 'epicsFloat32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\db\dbunittest.c(323): warning C4018: '<': signed/unsigned mismatch
dbStaticIocRegister.c
dbLoadTemplate.c
dbtoolsIocRegister.c
epicsRelease.c
../dbStatic/dbLex.l(484): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
../dbStatic/dbLex.l(158): warning C4244: 'initializing': conversion from '__int64' to 'int', possible loss of data
../dbStatic/dbLex.l(294): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
../dbStatic/dbLex.l(453): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
../dbtemplate/dbLoadTemplate_lex.l(311): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
../dbtemplate/dbLoadTemplate_lex.l(66): warning C4244: 'initializing': conversion from '__int64' to 'int', possible loss of data
../dbtemplate/dbLoadTemplate_lex.l(202): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
../dbtemplate/dbLoadTemplate_lex.l(361): warning C4244: '=': conversion from '__int64' to 'int', possible loss of data
iocInit.c
miscIocRegister.c
dlload.c
iocshRegisterCommon.c
registerAllRecordDeviceDrivers.cpp
registryRecordType.c
registryDeviceSupport.c
registryDriverSupport.c
registryJLinks.c
registryFunction.c
registryCommon.c
registryIocRegister.c
caserverio.c
caservertask.c
camsgtask.c
camessage.c
cast_server.c
online_notify.c
rsrvIocRegister.c
ascheck.c
h:\epics-devel\base-7.0.6\modules\database\src\ioc\rsrv\caservertask.c(82): warning C4244: 'function': conversion from 'SOCKET' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\rsrv\camessage.c(850): warning C4267: '=': conversion from 'size_t' to 'ca_uint32_t', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\ioc\rsrv\caservertask.c(157): warning C4018: '<': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\database\src\ioc\rsrv\camessage.c(937): warning C4267: '=': conversion from 'size_t' to 'ca_uint32_t', possible loss of datah:\epics-devel\base-7.0.6\modules\database\src\ioc\rsrv\caservertask.c(169): warning C4018: '<': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\database\src\ioc\rsrv\caservertask.c(218): warning C4018: '<=': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\database\src\ioc\rsrv\caservertask.c(253): warning C4018: '<': signed/unsigned mismatch
msi.cpp
   Creating library dbCore.lib and object dbCore.exp
Generating code
Generating code
Generating code
Generating code
aaiRecord.c
aaoRecord.c
aiRecord.c
aoRecord.c
aSubRecord.c
boRecord.c
biRecord.c
calcRecord.c
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\aairecord.c(212): warning C4244: '=': conversion from 'long' to 'short', possible loss of datah:\epics-devel\base-7.0.6\modules\database\src\std\rec\aaorecord.c(212): warning C4244: '=': conversion from 'long' to 'short', possible loss of data
calcoutRecord.c
compressRecord.c
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\aorecord.c(445): warning C4244: '=': conversion from 'short' to 'epicsUInt8', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\asubrecord.c(499): warning C4244: '=': conversion from 'long' to 'short', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\compressrecord.c(299): warning C4018: '>=': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\compressrecord.c(305): warning C4018: '>=': signed/unsigned mismatch
dfanoutRecord.c
eventRecord.c
fanoutRecord.c
histogramRecord.c
int64inRecord.c
int64outRecord.c
longinRecord.c
longoutRecord.c
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64inrecord.c(203): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64inrecord.c(204): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64inrecord.c(226): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64inrecord.c(227): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64inrecord.c(240): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64inrecord.c(241): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64inrecord.c(242): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64inrecord.c(243): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64outrecord.c(242): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64outrecord.c(243): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64outrecord.c(266): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64outrecord.c(267): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64outrecord.c(269): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64outrecord.c(270): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64outrecord.c(284): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64outrecord.c(285): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64outrecord.c(286): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\int64outrecord.c(287): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
lsiRecord.c
lsoRecord.c
mbbiRecord.c
mbbiDirectRecord.c
mbboRecord.c
mbboDirectRecord.c
permissiveRecord.c
printfRecord.c
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\lsirecord.c(51): warning C4267: '=': conversion from 'size_t' to 'epicsUInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\lsirecord.c(193): warning C4267: '=': conversion from 'size_t' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\lsorecord.c(55): warning C4267: '=': conversion from 'size_t' to 'epicsUInt16', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\lsorecord.c(134): warning C4267: '=': conversion from 'size_t' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\lsorecord.c(235): warning C4267: '=': conversion from 'size_t' to 'epicsUInt32', possible loss of data
selRecord.c
seqRecord.c
stateRecord.c
stringinRecord.c
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\printfrecord.c(246): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\printfrecord.c(314): warning C4244: '=': conversion from '__int64' to 'epicsUInt32', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\printfrecord.c(328): warning C4267: '=': conversion from 'size_t' to 'epicsUInt16', possible loss of data
stringoutRecord.c
subRecord.c
subArrayRecord.c
waveformRecord.c
devAaoSoft.c
devAaiSoft.c
devAiSoft.c
devAiSoftRaw.c
devAoSoft.c
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\subarrayrecord.c(166): warning C4244: '=': conversion from 'long' to 'short', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\subarrayrecord.c(192): warning C4018: '>': signed/unsigned mismatch
devAoSoftRaw.c
devBiSoft.c
h:\epics-devel\base-7.0.6\modules\database\src\std\rec\waveformrecord.c(181): warning C4244: '=': conversion from 'long' to 'short', possible loss of data
devBiSoftRaw.c
devBiDbState.c
devBoSoft.c
devBoSoftRaw.c
devBoDbState.c
devCalcoutSoft.c
devEventSoft.c
devHistogramSoft.c
devI64inSoft.c
devI64outSoft.c
devLiSoft.c
devLoSoft.c
devLsiSoft.c
devLsoSoft.c
devMbbiDirectSoft.c
devMbbiDirectSoftRaw.c
devMbbiSoft.c
devMbbiSoftRaw.c
devMbboDirectSoft.c
devMbboDirectSoftRaw.c
devMbboSoft.c
devMbboSoftRaw.c
devPrintfSoft.c
devSASoft.c
devSiSoft.c
devSoSoft.c
devWfSoft.c
devAiSoftCallback.c
devBiSoftCallback.c
h:\epics-devel\base-7.0.6\modules\database\src\std\dev\devsasoft.c(46): warning C4018: '>': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\database\src\std\dev\devsasoft.c(64): warning C4018: '>': signed/unsigned mismatch
h:\epics-devel\base-7.0.6\modules\database\src\std\dev\devsasoft.c(99): warning C4018: '>': signed/unsigned mismatch
devI64inSoftCallback.c
devLiSoftCallback.c
devMbbiDirectSoftCallback.c
devMbbiSoftCallback.c
devSiSoftCallback.c
devAoSoftCallback.c
devBoSoftCallback.c
devCalcoutSoftCallback.c
devI64outSoftCallback.c
devLoSoftCallback.c
devLsoSoftCallback.c
devMbboSoftCallback.c
devMbboDirectSoftCallback.c
devPrintfSoftCallback.c
devSoSoftCallback.c
devGeneralTime.c
devTimestamp.c
devStdio.c
devEnviron.c
asSubRecordFunctions.c
h:\epics-devel\base-7.0.6\modules\database\src\std\dev\devtimestamp.c(59): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
ts.c
dbnd.c
arr.c
h:\epics-devel\base-7.0.6\modules\database\src\std\dev\devenviron.c(59): warning C4267: '=': conversion from 'size_t' to 'epicsUInt32', possible loss of data
sync.c
decimate.c
utag.c
lnkConst.c
lnkCalc.c
lnkState.c
h:\epics-devel\base-7.0.6\modules\database\src\std\link\lnkconst.c(129): warning C4244: '=': conversion from '__int64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\link\lnkconst.c(182): warning C4244: '=': conversion from 'epicsInt64' to 'epicsFloat64', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\link\lnkconst.c(467): warning C4244: '=': conversion from 'long' to 'short', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\link\lnkconst.c(500): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\link\lnkcalc.c(128): warning C4244: '=': conversion from '__int64' to 'short', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\src\std\link\lnkcalc.c(143): warning C4244: '=': conversion from '__int64' to 'double', possible loss of data
lnkDebug.c
softMain.cpp
Generating code
Generating code
ioRecord.c
lnkStateTest.c
linkTest_registerRecordDeviceDriver.cpp
lnkCalcTest.c
h:\epics-devel\base-7.0.6\modules\database\test\std\link\lnkcalctest.c(68): warning C4244: 'function': conversion from 'epicsFloat64' to 'int', possible loss of data
   Creating library Recs.lib and object Recs.exp
Generating code
Generating code
Generating code
xRecord.c
arrRecord.c
tsTest.c
h:\epics-devel\base-7.0.6\modules\database\test\std\filters\arrrecord.c(121): warning C4244: '=': conversion from 'long' to 'short', possible loss of data
filterTest_registerRecordDeviceDriver.cpp
dbndTest.c
arrTest.cpp
syncTest.c
decTest.c
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
arrRecord.c
dbLinkdset.c
xRecord.c
devx.c
xLink.c
jlinkz.c
h:\epics-devel\base-7.0.6\modules\database\test\ioc\db\arrrecord.c(119): warning C4244: '=': conversion from 'long' to 'short', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\test\ioc\db\jlinkz.c(86): warning C4113: 'long (__cdecl *)()' differs in parameter lists from 'long (__cdecl *)(const epicsInt32 *,void *,const dbAddr *)'
h:\epics-devel\base-7.0.6\modules\database\test\ioc\db\jlinkz.c(127): warning C4113: 'long (__cdecl *)()' differs in parameter lists from 'long (__cdecl *)(epicsInt32 *,const void *,const dbAddr *)'
h:\epics-devel\base-7.0.6\modules\database\test\ioc\db\jlinkz.c(201): warning C4244: '=': conversion from '__int64' to 'epicsInt32', possible loss of data
dbScanTest.c
dbTestIoc_registerRecordDeviceDriver.cpp
dbShutdownTest.c
dbPutLinkTest.c
dbLockTest.c
dbStressLock.c
asTestLib.c
h:\epics-devel\base-7.0.6\modules\database\test\ioc\db\dbputlinktest.c(114): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
dbHeaderTest.c
h:\epics-devel\base-7.0.6\modules\database\test\std\rec\astestlib.c(288): warning C4113: 'DEVSUPFUN' differs in parameter lists from 'long (__cdecl *)(dbCommon *)'
h:\epics-devel\base-7.0.6\modules\database\test\std\rec\astestlib.c(289): warning C4113: 'DEVSUPFUN' differs in parameter lists from 'long (__cdecl *)(dbCommon *)'
testdbConvert.c
dbHeaderTestxx.cpp
h:\epics-devel\base-7.0.6\modules\database\test\ioc\db\testdbconvert.c(123): warning C4267: '=': conversion from 'size_t' to 'short', possible loss of data
callbackTest.c
arrayOpTest.c
recTestIoc_registerRecordDeviceDriver.cpp
callbackParallelTest.c
dbStateTest.c
recMiscTest.c
dbServerTest.c
linkRetargetLinkTest.c
dbCaStatsTest.c
linkInitTest.c
dbCaLinkTest.c
compressTest.c
asyncSoftTest.c
dbCACTest.cpp
softTest.c
seqTest.c
dbDbLinkTest.c
asTest.c
scanIoTest.c
h:\epics-devel\base-7.0.6\modules\database\test\ioc\db\dbcactest.cpp(36): warning C4267: 'argument': conversion from 'size_t' to 'unsigned long', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\test\ioc\db\dbcactest.cpp(44): warning C4267: 'argument': conversion from 'size_t' to 'unsigned long', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\test\std\rec\softtest.c(144): warning C4244: '=': conversion from 'epicsFloat64' to 'int', possible loss of data
asTestIoc_registerRecordDeviceDriver.cpp
dbChannelTest.c
analogMonitorTest.c
dbChArrTest.cpp
dbChArrTest_registerRecordDeviceDriver.cpp
analogMonitorTest_registerRecordDeviceDriver.cpp
chfPluginTest.c
arrShorthandTest.c
scanEventTest.c
scanEventTest_registerRecordDeviceDriver.cpp
benchdbConvert.c
h:\epics-devel\base-7.0.6\modules\database\test\ioc\db\benchdbconvert.c(37): warning C4267: 'function': conversion from 'size_t' to 'long', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\test\ioc\db\benchdbconvert.c(62): warning C4267: '=': conversion from 'size_t' to 'short', possible loss of data
h:\epics-devel\base-7.0.6\modules\database\test\ioc\db\benchdbconvert.c(63): warning C4267: '=': conversion from 'size_t' to 'long', possible loss of data
regressTest.c
regressTest_registerRecordDeviceDriver.cpp
recGblCheckDeadbandTest.c
simmTest.c
dbPutGetTest.c
simmTest_registerRecordDeviceDriver.cpp
mbbioDirectTest.c
asyncproctest.c
asyncproctest_registerRecordDeviceDriver.cpp
dbStaticTest.c
linkFilterTest.c
   Creating library dbTestIoc.lib and object dbTestIoc.exp
Generating code
   Creating library dbRecStdTest.lib and object dbRecStdTest.exp
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
Generating code
dbHeaderTest.c
dbHeaderTestxx.cpp
Generating code
Generating code
Re: Building base 7.0.6 with parallel make fails on windows-x64 Michael Davidsaver via Core-talk
Building base 7.0.6 with parallel make fails on windows-x64 Mark Rivers via Core-talk
Re: Building base 7.0.6 with parallel make fails on windows-x64 Johnson, Andrew N. via Core-talk
Prev: Build completed: EPICS Base 7 base-7.0-388 AppVeyor via Core-talk
Next: Re: Building base 7.0.6 with parallel make fails on windows-x64 Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Re: Building base 7.0.6 with parallel make fails on windows-x64 Johnson, Andrew N. via Core-talk
ANJ, 20 Sep 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
