On 9/20/21 1:42 PM, Mark Rivers via Core-talk wrote:
> Hi Andrew,
> Ø How repeatable is the failure?
> I seem to have repeatable problems, but they are not exactly what I saw before.
> This is the output when I do “make clean uninstall” and then “make –sj8”, putting the output in file build3.txt.
Is '-s' necessary to reproduce? If not, omitting this might give
some idea of exactly what the malformed command is.
Also maybe worthwhile asking a couple of ~silly background questions.
Which 'make' build/version is in use?
Which perl disto/version?
Is H: a local disk or network share?
Any notable environment variables effecting make? (eg. '%SHELL%' or '%MAKESHELL%')
I'm wondering if ".." is a symptom of using 'cmd' instead of 'bash'
shell.
> H:\epics-devel\base-7.0.6>make -sj clean uninstall
> H:\epics-devel\base-7.0.6>make -sj8 > build3.txt
> toolchain.c
> '..' is not recognized as an internal or external command,
> operable program or batch file.
> I have attached the output file from that build, build3.txt. I don’t see any errors. However, it did not build the pvAccess, pvDatabase, etc. modules. These are the only DLLs in bin\windows-x64.
> H:\epics-devel\base-7.0.6>dir bin\windows-x64\*.dll
> Volume in drive H is local_rw
> Volume Serial Number is 6DDD-530A
> Directory of H:\epics-devel\base-7.0.6\bin\windows-x64
> 09/20/2021 03:15 PM 438,784 Com.dll
> 09/20/2021 03:18 PM 317,440 ca.dll
> 09/20/2021 03:21 PM 549,888 dbCore.dll
> 09/20/2021 03:24 PM 307,200 dbRecStd.dll
> 4 File(s) 1,613,312 bytes
> 0 Dir(s) 700,124,401,664 bytes free
> That does not seem correct, there should be many more DLLs.
> I then just run “make –sj” again without cleaning first, putting the output in build4.txt
> H:\epics-devel\base-7.0.6>make -sj8 > build4.txt
> There was no command line output. The build did not create the missing DLLs. I have attached build4.txt as well.
> Thanks,
> Mark
> *From:*Johnson, Andrew N. <anj at anl.gov>
> *Sent:* Wednesday, September 15, 2021 5:45 PM
> *To:* Mark Rivers <rivers at cars.uchicago.edu>
> *Cc:* EPICS core-talk <core-talk at aps.anl.gov>
> *Subject:* Re: Building base 7.0.6 with parallel make fails on windows-x64
> Hi Mark,
> On Sep 11, 2021, at 9:02 AM, Mark Rivers via Core-talk <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
> I tried to build base 7.0.6 on windows-x64 using “make –sj8” on an 8-core machine. It failed as follows:
> softIoc_registerRecordDeviceDriver.cpp
> softMain.cpp
> Creating library dbRecStd.lib and object dbRecStd.exp
> Generating code
> Finished generating code
> Generating code
> The above files and dbCommon.dbd are built within modules/database/src.
> dbdExpand.pl: Can't find file 'dbCommon.dbd'
> while reading 'base.dbd' to create 'recTestIoc.dbd'
> dbdExpand.pl: Exiting due to errors
> make[5]: *** [../../../../../../configure/RULES.Db:403: ../O.Common/recTestIoc.dbd] Error 2
> make[5]: *** Waiting for unfinished jobs....
> make[4]: *** [../../../../../configure/RULES_ARCHS:58: install.windows-x64] Error 2
> make[3]: *** [../../../configure/RULES_DIRS:85: std/rec.install] Error 2
> make[3]: *** Waiting for unfinished jobs....
> The recTestIoc.dbd file is created within modules/database/test/std/rec which is built as a subdirectory of modules/database/test. There is a hard dependency specified in modules/database/Makefile so it isn’t supposed to be possible to start building in the test directory until the src directory has finished building:
> DIRS += src
> DIRS += test
> test_DEPEND_DIRS = src
> Thus I’m having difficulty imagining how that failure can occur (I’m not saying it couldn’t, I just don’t see how at the moment). How repeatable is the failure?
> Running make –sj8 again appeared to work although it started with this message:
> asTestLib.c
> dbHeaderTest.c
> arrayOpTest.c
> Those .c files are compiled in the modules/database/test/std/rec directory, which makes sense given the failure above. I’ll see if I can work out what the ‘..’ program might have been in case it provides more clues.
> - Andrew
> Complexity comes for free, simplicity you have to work for.
- RE: Building base 7.0.6 with parallel make fails on windows-x64 Mark Rivers via Core-talk
- Building base 7.0.6 with parallel make fails on windows-x64 Mark Rivers via Core-talk
- Re: Building base 7.0.6 with parallel make fails on windows-x64 Johnson, Andrew N. via Core-talk
<2021>
2025
2026
<2021>
2025
2026
