2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: RE: [EXTERNAL] CA gateway chaining
From: "Pearson, Matthew R. via Core-talk" <core-talk at aps.anl.gov>
To: Timo Korhonen <Timo.Korhonen at ess.eu>, Ralph Lange <ralph.lange at gmx.de>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Mon, 1 Nov 2021 17:19:07 +0000
We have seen similar issues and one way we dealt with it was to provide a heavily re-binned array for use via gateways. Inside the beamline network we provide both a full un-binned array, hidden behind ‘detailed’ buttons, as well as the re-binned array screens that users will first encounter on higher level screens. We also limited the array size that the gateway will transmit, so some of the larger arrays don’t work which forces people to view the re-binned arrays.
Also, depending on the original data type and software, you can ‘compress’ the array data from 16 or 32-bit down to 8-bit data by re-scaling it to 0-255, like a JPEG image. Then the waveform data type can be set to UCHAR.
The above only works if the waveforms are simply for visualization.
Cheers,
Matt
From: Core-talk <core-talk-bounces at aps.anl.gov> On Behalf Of Timo Korhonen via Core-talk
Sent: Monday, November 1, 2021 11:36 AM
To: Ralph Lange <ralph.lange at gmx.de>; EPICS Core Talk <core-talk at aps.anl.gov>
Subject: Re: [EXTERNAL] CA gateway chaining
Right, this is the way we are going for now. It is not exactly trivial to manage but should be doable.
TImo
From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of EPICS Core Talk <core-talk at aps.anl.gov>
Reply-To: Ralph Lange <
Date: Monday, 1 November 2021 at 16:18
To: EPICS Core Talk <
On Wed, 27 Oct 2021 at 10:49, Timo Korhonen via Core-talk <core-talk at aps.anl.gov> wrote:
Just a short follow-up.
We found out that the delays are due to large arrays being monitored over the gateway. Not a surprise, even if we have tried to remind users about the effects with big arrays.
One way to mitigate this - I think this approach was implemented at some point at the SLS - is to route the large array channels through a dedicated separate gateway instance.
(Ease of configuration depends on your naming convention.)
Cheers,
~Ralph
Re: [EXTERNAL] CA gateway chaining Timo Korhonen via Core-talk
Re: [EXTERNAL] CA gateway chaining Hartman, Steven via Core-talk
Re: [EXTERNAL] CA gateway chaining Zimoch Dirk (PSI) via Core-talk
Re: [EXTERNAL] CA gateway chaining Ralph Lange via Core-talk
Prev: Re: [EXTERNAL] CA gateway chaining Timo Korhonen via Core-talk
Next: Re: [EXTERNAL] CA gateway chaining Timo Korhonen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 01 Nov 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
