> Can you link an example?
https://github.com/search?q=org%3Aepics-modules+iocshArgPersistentString&type=code
I get 2 results in epics-modules, one from drvIpac and one from caPutLog:
https://github.com/epics-modules/ipac/blob/5efbc9e70231c5e5dd49ba90c8532dcc808e9e39/drvTip810/drvTip810.c#L1450
This code is not currently NULL-safe, https://github.com/epics-modules/ipac/issues/9
https://github.com/epics-modules/caPutLog/blob/02ba23271650b4c4a719aadb69d393eb79aab2c8/caPutLogApp/caPutLogShellCommands.c#L39
Recently merged code by Dirk, this does handle NULLs properly.
This particular bug has been resolved now though.
** Bug watch added: github.com/epics-modules/ipac/issues #9
** Changed in: epics-base/7.0
Status: Triaged => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1824732
Title:
iocsh crashes when dealing with NULL iocshArgPersistentString
Status in EPICS Base:
Fix Released
Status in EPICS Base 3.15 series:
Triaged
Status in EPICS Base 7.0 series:
Fix Released
Bug description:
I was looking at the iocsh.cpp (@R7.0.2.1) code and realized that
there's a bug when parsing command arguments of type
iocshArgPersistentString. The code in cvtArg does the following:
case iocshArgPersistentString:
argBuf->sval = (char *) malloc(strlen(arg) + 1);
if (argBuf->sval == NULL) {
showError(filename, lineno, "Out of memory");
return 0;
strcpy(argBuf->sval, arg);
break;
However, here 'arg' can be NULL, so 'strlen' can (will?) SEGFAULT. I
was able to successfully trigger the issue. I don't know where this is
used or who uses this functionality exactly.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1824732/+subscriptions
[Bug 541388] Re: ca reference manual issues Andrew Johnson via Core-talk
[Bug 1824732] Re: iocsh crashes when dealing with NULL iocshArgPersistentString Andrew Johnson via Core-talk
<2022>
2025
2026
<2022>
2025
2026
