2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: [Bug 1824732] Re: iocsh crashes when dealing with NULL iocshArgPersistentString
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 10 May 2022 22:59:48 -0000
But not on the 3.15 branch, that could get the fix if anyone feels like
back-porting the code change from the 7.0 branch.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1824732
Title:
Status in EPICS Base:
  Fix Released
Status in EPICS Base 3.15 series:
  Triaged
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  I was looking at the iocsh.cpp (@R7.0.2.1) code and realized that
  there's a bug when parsing command arguments of type
  iocshArgPersistentString. The code in cvtArg does the following:
     case iocshArgPersistentString:
          argBuf->sval = (char *) malloc(strlen(arg) + 1);
          if (argBuf->sval == NULL) {
              showError(filename, lineno, "Out of memory");
              return 0;
          strcpy(argBuf->sval, arg);
          break;
  However, here 'arg' can be NULL, so 'strlen' can (will?) SEGFAULT. I
  was able to successfully trigger the issue. I don't know where this is
  used or who uses this functionality exactly.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1824732/+subscriptions
Prev: [Bug 1824732] Re: iocsh crashes when dealing with NULL iocshArgPersistentString Andrew Johnson via Core-talk
Next: [Bug 541180] Re: numeric bounds on enumerated types should be based on enumerated string table limits mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
