2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: pvPutLog?
From: Timo Korhonen via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>, Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 21 Jun 2022 14:26:42 +0000
Colleagues,
The topic of put logging came up in our discussions at ESS again. I found this old thread and tried to scratch my memory where we ended with this. I thought this was working (with PVA as well) but I am not sure anymore, and re-reading the thread could not enlighten me either.
Access security works exactly as discussed for us, with Posix groups (PVA-only) and all that, and I assumed that the put-logging issue was resolved as a part of that implementation, but is there still something missing?
Timo
On 2019-09-06, 14:39, "core-talk-bounces at aps.anl.gov on behalf of Johnson, Andrew N. via Core-talk" <core-talk-bounces at aps.anl.gov on behalf of core-talk at aps.anl.gov> wrote:
    Hi Michael,
    > On Sep 4, 2019, at 4:45 AM, Michael Davidsaver <mdavidsaver at gmail.com> wrote:
    > https://github.com/epics-modules/caPutLog/blob/b544f92c6efe1df98506b567f3f7e5137965e2a4/caPutLogApp/caPutLogAs.c#L104
    > dbGetField() is used, which of course calls dbScanLock().
    > This is done twice, for the "before" and "after" values.
    > So 'pmessage->data' is not used.
    > I guess I can just pass data=NULL or a dummy value.
    Please look at commit c5ded30684 in Base. The asTrapWrite.h API was enhanced about 4 years ago in 3.15 and caPutLog is no longer the only external user of it. Tim Mooney's caPutRecorder module *does* rely on pmessage->data. Direct access to the data was added on his request, so he can record exactly what value was put even if the record processing subsequently modifies that field value (puts to the Motor record can fall into that category).
    Someone could modify caPutLog to make use of the data field instead of calling dbGetField() twice.
    - Andrew
Re: pvPutLog? Johnson, Andrew N. via Core-talk
Prev: Build completed: epics-base base-7.0-861 AppVeyor via Core-talk
Next: Re: pvPutLog? Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
