On Mon, 2022-06-27 at 15:12 +0200, Zimoch Dirk wrote:
> The problem appears between commit 4ab98081 and 56f05d72. (The two commits in between do not produce stable code.)
Ben did some code refactoring of db_field_log which changed array handling.
In particular in dbEvent.c the following snipped disappeared from db_queue_event_log()
* if we have an event on the queue and both the last
* event on the queue and the current event are emtpy
* (i.e. of type dbfl_type_rec), simply ignore duplicate
* events (saving empty events serves no purpose)
if (pevent->npend > 0u &&
(*pevent->pLastLog)->type == dbfl_type_rec &&
pLog->type == dbfl_type_rec) {
db_delete_field_log(pLog);
UNLOCKEVQUE (ev_que);
return;
I have added a debug printf in this code and see that it triggers whenever a frame is dropped. That is about 3 out of 4
frames in my test case.
It is not trivial to put back the code because dbfl_type_rec disappeared from enum dbfl_type too.
I also could not easily revert the merge commit 50419144.
I think Ben's help is needed here.
Dirk
- Re: Problem with huge waveforms in EPICS 7 Michael Davidsaver via Core-talk
- Problem with huge waveforms in EPICS 7 Zimoch Dirk (PSI) via Core-talk
- Re: Problem with huge waveforms in EPICS 7 Andrew Johnson via Core-talk
- Re: Problem with huge waveforms in EPICS 7 Zimoch Dirk (PSI) via Core-talk
<2022>
2025
2026
<2022>
2025
2026
