This issue is nothing to do with my RTEMS-uC5282 build, it's
RTEMS-pc686 where the problem is. In my RTEMS-5.1 bsp.h header there
is a declaration of this function that conflicts with ours:
tux%
cd /local/anj/RTEMS-5.1/rtems-5.1
tux% ack -C3 rtems_3c509_driver_attach
i386-rtems5/pc686/lib/include/bsp.h
95-#define BSP_DEC21140_NETWORK_DRIVER_NAME "dc1"
96-#define BSP_DEC21140_NETWORK_DRIVER_ATTACH
rtems_dec21140_driver_attach
97-
98:extern int rtems_3c509_driver_attach(struct
rtems_bsdnet_ifconfig *config);
99-#define BSP_3C509_NETWORK_DRIVER_NAME "3c1"
100:#define BSP_3C509_NETWORK_DRIVER_ATTACH
101-
102-#ifndef RTEMS_BSP_NETWORK_DRIVER_NAME
103-#define RTEMS_BSP_NETWORK_DRIVER_NAME
tux%
cd /home/phoebus/ANJ/epics/base/7.0
modules/libcom/RTEMS/rtems_netconfig.c
71- rtems_fxp_attach, /* attach function */
72- &ne2k_driver_config, /* link to next
interface */
73-};
74:// extern int rtems_3c509_driver_attach (struct
rtems_bsdnet_ifconfig *, int);
75-static struct rtems_bsdnet_ifconfig e3c509_driver_config = {
76- "ep0", /* name */
77: rtems_3c509_driver_attach, /* attach function */
78- &fxp_driver_config, /* link to next
interface */
79-};
80-#define FIRST_DRIVER_CONFIG &e3c509_driver_config
I don't understand why this isn't causing similar problems with the
GHA builds, presumably Michael's RTEMS installation is different
somehow. Can we just remove the function declaration or is it more
complicated than that?
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Re: RTEMS build issue, rtems_3c509_driver_attach Michael Davidsaver via Core-talk
epics-7.0 » linux32 - Build # 411 - Still Unstable! APS Jenkins via Core-talk
<2022>
2025
2026
epics-7.0 » linux32 - Build # 432 - Still Unstable! APS Jenkins via Core-talk
<2022>
2025
2026
ANJ, 25 Sep 2022 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
