2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: RE: readline in base 7.0.7
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Fri, 30 Sep 2022 21:50:09 +0000
Hi Michael,
I just tried your patch, and it does not build.
corvette:local/epics-devel/base-7.0.7>patch -p1 < patch1
patching file configure/toolchain.c
corvette:local/epics-devel/base-7.0.7>git diff configure/toolchain.c
diff --git a/configure/toolchain.c b/configure/toolchain.c
index 2f76b47..bc37cad 100644
--- a/configure/toolchain.c
+++ b/configure/toolchain.c
@@ -45,5 +45,7 @@ COMMANDLINE_LIBRARY ?= READLINE
COMMANDLINE_LIBRARY ?= EPICS
#  endif
#else
-COMMANDLINE_LIBRARY ?= EPICS
+COMMANDLINE_LIBRARY ?= $(strip $(if $(wildcard \
+    $(if $(GNU_DIR),$(GNU_DIR)/include/readline/readline.h) \
+), READLINE, EPICS))
#endif
My diff looks just like your patch, so I think I did it correctly.
However, it fails to build and I can't figure out the problem, since the parentheses do match.
corvette:local/epics-devel/base-7.0.7>make
make -C ./configure install
make[1]: Entering directory `/usr/local/epics-devel/base-7.0.7/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory `/usr/local/epics-devel/base-7.0.7/configure/O.linux-x86_64'
../../cfg/TOOLCHAIN.linux-x86_64.linux-x86_64:13: *** missing separator.  Stop.
make[2]: Leaving directory `/usr/local/epics-devel/base-7.0.7/configure/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/usr/local/epics-devel/base-7.0.7/configure'
make: *** [configure.install] Error 2
-----Original Message-----
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Friday, September 9, 2022 6:28 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: core-talk at aps.anl.gov
Subject: Re: readline in base 7.0.7
On 9/8/22 11:44, Mark Rivers wrote:
>  > You will need to manually specify COMMANDLINE_LIBRARY for the time being.  (and hopefully put an OS upgrade on your roadmap)
> This is unfortunate, since the automatic detection worked fine in base 7.0.6.1.
fyi.  https://github.com/epics-base/epics-base/pull/254
As always, I would encourage those interested to follow PRs.
Compatibility doesn't just happen by itself.
The following lightly tested patch should restore the previous
$(GNU_DIR) automatic detection for older compilers.  (not just
linux)
> index 2f76b475b..bc37cad64 100644
>  #  endif
>  #else
>  #endif
> The release notes really should say that manual editing is now required for older compilers, while it previously was not.
Specific suggestions on wording are welcomed.  I find it
difficult to write succinct documentation which speaks
to every user.
>  They should also say which version of gcc is required to have the automatic detection work.
GCC >=5.0
https://gcc.gnu.org/projects/cxx-status.html#cxx17
I don't know when clang or msvc added support.
>  I now need to spend a few hours rebuilding base and synApps for a bunch of architectures.
I'm sorry to have wasted your time.
>  > and hopefully put an OS upgrade on your roadmap)
> We have a number of machines where vendor support for kernel drivers limits such upgrades.  RHEL 7 has 2 more years before EOL, and is still used on many APS beamlines.
> Mark
> Sent: Thursday, September 8, 2022 1:29 PM
> On 9/8/22 10:40, Mark Rivers via Core-talk wrote:
>  > I just built base 7.0.7 on Centos 7 with no changes to the files in configure/os.
> Right, I wasn't paying attention.  Automatic detection now depends on GCC version.  As I recall, centos7 has GCC 4.8, which is too old.
>  > My IOCs now are not built with libreadline, while in base 7.0.6.1 they were, again with no changes to the configure/os files.
>  > I see this change between base 7.0.6.1 and base 7.0.7
>  > corvette:base-7.0.7/configure/os>git diff R7.0.6.1 R7.0.7
>  > CONFIG_SITE.Common.linux-x
>  > CONFIG_SITE.Common.linux-x86        CONFIG_SITE.Common.linux-x86_64
>  > CONFIG_SITE.Common.linux-xscale_be
>  > CONFIG_SITE.Common.linux-x86_64
>  > diff --git a/configure/os/CONFIG_SITE.Common.linux-x86_64
>  > b/configure/os/CONFIG_SITE.Common.linux-x86_64
>  > index e098b76..b98385f 100644
>  > --- a/configure/os/CONFIG_SITE.Common.linux-x86_64
>  > +++ b/configure/os/CONFIG_SITE.Common.linux-x86_64
>  > @@ -15,10 +15,6 @@
>  > #    to inform the system of the shared library location.
>  > -# Use GNU Readline if the header file is installed
>  > -COMMANDLINE_LIBRARY = $(strip $(if $(wildcard \
>  > -    $(GNU_DIR)/include/readline/readline.h), READLINE, EPICS))
>  > # If libreadline needs additional libraries to be linked with it, try
>  > # uncommenting each of the lines below in turn, starting with the top
>  > # one and working downwards, until the build succeeds. Do a 'make rebuild'
>  > The release notes say:
>  > *Automatic COMMANDLINE_LIBRARY w/ newer compilers*
>  > When built with a compiler supporting __has_include<>, the presence of the <readline/readline.h> will be used to automatically determine a default value for COMMANDLINE_LIBRARY.
>  > Mingw builds with readline support now link -ltermcap instead of -lcurses.
>  > This should not effect sites which set explicitly set COMMANDLINE_LIBRARY as the only definition in Base now has the form COMMANDLINE_LIBRARY ?= ....
>  > I interpret the first sentence here to mean that the test for
>  > COMMANDLINE_LIBRARY is done in the compiler if possible, but it does
>  > not say that the previous way of doing it in the CONFIG_SITE file (for
>  > older compilers) has been removed
>  > Does this mean that I now need to edit CONFIG_SITE.Common.linux-x86_64 to manually set COMMANDLINE_LIBRARY?
>  > Thanks,
>  > Mark
Re: readline in base 7.0.7 Michael Davidsaver via Core-talk
readline in base 7.0.7 Mark Rivers via Core-talk
RE: readline in base 7.0.7 Mark Rivers via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-693 AppVeyor via Core-talk
Next: Re: readline in base 7.0.7 Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: readline in base 7.0.7 Mark Rivers via Core-talk
ANJ, 30 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
