Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=mac/433/ This job failed to build. Started by upstream project "epics-7.0" build number 433 originally caused by: Started by user Andrew Johnson Running as SYSTEM [EnvInject] - Loading node environment variables. Building remotely on mac-1 (mac) in workspace /Users/jenkins/workspace/epics-7.0/OS/mac The recommended git tool is: NONE No credentials specified > git rev-parse --resolve-git-dir /Users/jenkins/workspace/epics-7.0/OS/mac/.git # timeout=10 Fetching changes from the remote Git repository > git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10 Fetching upstream changes from https://git.launchpad.net/epics-base/ > git --version # timeout=10 > git --version # 'git version 2.21.1 (Apple Git-122.3)' Setting http proxy: webproxy1.anl.gov:9091 > git fetch --tags --force --progress -- https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/* # timeout=10 ERROR: Error fetching remote repo 'origin' hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base/ at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1006) at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1248) at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1312) at hudson.scm.SCM.checkout(SCM.java:540) at hudson.model.AbstractProject.checkout(AbstractProject.java:1217) at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:647) at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:85) at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:519) at hudson.model.Run.execute(Run.java:1897) at hudson.matrix.MatrixRun.run(MatrixRun.java:153) at hudson.model.ResourceController.execute(ResourceController.java:101) at hudson.model.Executor.run(Executor.java:442) Caused by: hudson.plugins.git.GitException: Command "git fetch --tags --force --progress -- https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*" returned status code 1: stdout: stderr: remote: Enumerating objects: 1442 remote: Enumerating objects: 2066, done. remote: Counting objects: 0% (1/1820) remote: Counting objects: 1% (19/1820) remote: Counting objects: 2% (37/1820) remote: Counting objects: 3% (55/1820) remote: Counting objects: 4% (73/1820) remote: Counting objects: 5% (91/1820) remote: Counting objects: 6% (110/1820) remote: Counting objects: 7% (128/1820) remote: Counting objects: 8% (146/1820) remote: Counting objects: 9% (164/1820) remote: Counting objects: 10% (182/1820) remote: Counting objects: 11% (201/1820) remote: Counting objects: 12% (219/1820) remote: Counting objects: 13% (237/1820) remote: Counting objects: 14% (255/1820) remote: Counting objects: 15% (273/1820) remote: Counting objects: 16% (292/1820) remote: Counting objects: 17% (310/1820) remote: Counting objects: 18% (328/1820) remote: Counting objects: 19% (346/1820) remote: Counting objects: 20% (364/1820) remote: Counting objects: 21% (383/1820) remote: Counting objects: 22% (401/1820) remote: Counting objects: 23% (419/1820) remote: Counting objects: 24% (437/1820) remote: Counting objects: 25% (455/1820) remote: Counting objects: 26% (474/1820) remote: Counting objects: 27% (492/1820) remote: Counting objects: 28% (510/1820) remote: Counting objects: 29% (528/1820) remote: Counting objects: 30% (546/1820) remote: Counting objects: 31% (565/1820) remote: Counting objects: 32% (583/1820) remote: Counting objects: 33% (601/1820) remote: Counting objects: 34% (619/1820) remote: Counting objects: 35% (637/1820) remote: Counting objects: 36% (656/1820) remote: Counting objects: 37% (674/1820) remote: Counting objects: 38% (692/1820) remote: Counting objects: 39% (710/1820) remote: Counting objects: 40% (728/1820) remote: Counting objects: 41% (747/1820) remote: Counting objects: 42% (765/1820) remote: Counting objects: 43% (783/1820) remote: Counting objects: 44% (801/1820) remote: Counting objects: 45% (819/1820) remote: Counting objects: 46% (838/1820) remote: Counting objects: 47% (856/1820) remote: Counting objects: 48% (874/1820) remote: Counting objects: 49% (892/1820) remote: Counting objects: 50% (910/1820) remote: Counting objects: 51% (929/1820) remote: Counting objects: 51% (940/1820) remote: Counting objects: 52% (947/1820) remote: Counting objects: 53% (965/1820) remote: Counting objects: 54% (983/1820) remote: Counting objects: 55% (1001/1820) remote: Counting objects: 56% (1020/1820) remote: Counting objects: 57% (1038/1820) remote: Counting objects: 58% (1056/1820) remote: Counting objects: 59% (1074/1820) remote: Counting objects: 60% (1092/1820) remote: Counting objects: 61% (1111/1820) remote: Counting objects: 62% (1129/1820) remote: Counting objects: 63% (1147/1820) remote: Counting objects: 64% (1165/1820) remote: Counting objects: 65% (1183/1820) remote: Counting objects: 66% (1202/1820) remote: Counting objects: 67% (1220/1820) remote: Counting objects: 68% (1238/1820) remote: Counting objects: 69% (1256/1820) remote: Counting objects: 70% (1274/1820) remote: Counting objects: 71% (1293/1820) remote: Counting objects: 72% (1311/1820) remote: Counting objects: 73% (1329/1820) remote: Counting objects: 74% (1347/1820) remote: Counting objects: 75% (1365/1820) remote: Counting objects: 76% (1384/1820) remote: Counting objects: 77% (1402/1820) remote: Counting objects: 78% (1420/1820) remote: Counting objects: 79% (1438/1820) remote: Counting objects: 80% (1456/1820) remote: Counting objects: 81% (1475/1820) remote: Counting objects: 82% (1493/1820) remote: Counting objects: 83% (1511/1820) remote: Counting objects: 84% (1529/1820) remote: Counting objects: 85% (1547/1820) remote: Counting objects: 86% (1566/1820) remote: Counting objects: 87% (1584/1820) remote: Counting objects: 88% (1602/1820) remote: Counting objects: 89% (1620/1820) remote: Counting objects: 90% (1638/1820) remote: Counting objects: 91% (1657/1820) remote: Counting objects: 92% (1675/1820) remote: Counting objects: 93% (1693/1820) remote: Counting objects: 94% (1711/1820) remote: Counting objects: 95% (1729/1820) remote: Counting objects: 96% (1748/1820) remote: Counting objects: 97% (1766/1820) remote: Counting objects: 98% (1784/1820) remote: Counting objects: 99% (1802/1820) remote: Counting objects: 100% (1820/1820) remote: Counting objects: 100% (1820/1820), done. remote: Compressing objects: 0% (1/1037) remote: Compressing objects: 1% (11/1037) remote: Compressing objects: 2% (21/1037) remote: Compressing objects: 3% (32/1037) remote: Compressing objects: 4% (42/1037) remote: Compressing objects: 5% (52/1037) remote: Compressing objects: 6% (63/1037) remote: Compressing objects: 7% (73/1037) remote: Compressing objects: 8% (83/1037) remote: Compressing objects: 9% (94/1037) remote: Compressing objects: 10% (104/1037) remote: Compressing objects: 11% (115/1037) remote: Compressing objects: 12% (125/1037) remote: Compressing objects: 13% (135/1037) remote: Compressing objects: 14% (146/1037) remote: Compressing objects: 15% (156/1037) remote: Compressing objects: 16% (166/1037) remote: Compressing objects: 17% (177/1037) remote: Compressing objects: 18% (187/1037) remote: Compressing objects: 19% (198/1037) remote: Compressing objects: 20% (208/1037) remote: Compressing objects: 21% (218/1037) remote: Compressing objects: 22% (229/1037) remote: Compressing objects: 23% (239/1037) remote: Compressing objects: 24% (249/1037) remote: Compressing objects: 25% (260/1037) remote: Compressing objects: 26% (270/1037) remote: Compressing objects: 27% (280/1037) remote: Compressing objects: 28% (291/1037) remote: Compressing objects: 29% (301/1037) remote: Compressing objects: 30% (312/1037) remote: Compressing objects: 31% (322/1037) remote: Compressing objects: 32% (332/1037) remote: Compressing objects: 33% (343/1037) remote: Compressing objects: 34% (353/1037) remote: Compressing objects: 35% (363/1037) remote: Compressing objects: 36% (374/1037) remote: Compressing objects: 37% (384/1037) remote: Compressing objects: 38% (395/1037) remote: Compressing objects: 39% (405/1037) remote: Compressing objects: 40% (415/1037) remote: Compressing objects: 41% (426/1037) remote: Compressing objects: 42% (436/1037) remote: Compressing objects: 43% (446/1037) remote: Compressing objects: 44% (457/1037) remote: Compressing objects: 45% (467/1037) remote: Compressing objects: 46% (478/1037) remote: Compressing objects: 47% (488/1037) remote: Compressing objects: 48% (498/1037) remote: Compressing objects: 49% (509/1037) remote: Compressing objects: 50% (519/1037) remote: Compressing objects: 51% (529/1037) remote: Compressing objects: 52% (540/1037) remote: Compressing objects: 53% (550/1037) remote: Compressing objects: 54% (560/1037) remote: Compressing objects: 55% (571/1037) remote: Compressing objects: 56% (581/1037) remote: Compressing objects: 57% (592/1037) remote: Compressing objects: 58% (602/1037) remote: Compressing objects: 59% (612/1037) remote: Compressing objects: 60% (623/1037) remote: Compressing objects: 61% (633/1037) remote: Compressing objects: 62% (643/1037) remote: Compressing objects: 63% (654/1037) remote: Compressing objects: 64% (664/1037) remote: Compressing objects: 65% (675/1037) remote: Compressing objects: 66% (685/1037) remote: Compressing objects: 67% (695/1037) remote: Compressing objects: 68% (706/1037) remote: Compressing objects: 69% (716/1037) remote: Compressing objects: 70% (726/1037) remote: Compressing objects: 71% (737/1037) remote: Compressing objects: 72% (747/1037) remote: Compressing objects: 73% (758/1037) remote: Compressing objects: 74% (768/1037) remote: Compressing objects: 75% (778/1037) remote: Compressing objects: 76% (789/1037) remote: Compressing objects: 77% (799/1037) remote: Compressing objects: 78% (809/1037) remote: Compressing objects: 79% (820/1037) remote: Compressing objects: 80% (830/1037) remote: Compressing objects: 81% (840/1037) remote: Compressing objects: 82% (851/1037) remote: Compressing objects: 83% (861/1037) remote: Compressing objects: 84% (872/1037) remote: Compressing objects: 85% (882/1037) remote: Compressing objects: 86% (892/1037) remote: Compressing objects: 87% (903/1037) remote: Compressing objects: 88% (913/1037) remote: Compressing objects: 89% (923/1037) remote: Compressing objects: 90% (934/1037) remote: Compressing objects: 91% (944/1037) remote: Compressing objects: 92% (955/1037) remote: Compressing objects: 93% (965/1037) remote: Compressing objects: 94% (975/1037) remote: Compressing objects: 95% (986/1037) remote: Compressing objects: 96% (996/1037) remote: Compressing objects: 97% (1006/1037) remote: Compressing objects: 98% (1017/1037) remote: Compressing objects: 99% (1027/1037) remote: Compressing objects: 100% (1037/1037) remote: Compressing objects: 100% (1037/1037), done. Receiving objects: 0% (1/1339) Receiving objects: 1% (14/1339) Receiving objects: 2% (27/1339) Receiving objects: 3% (41/1339) Receiving objects: 4% (54/1339) Receiving objects: 5% (67/1339) Receiving objects: 6% (81/1339) Receiving objects: 7% (94/1339) Receiving objects: 8% (108/1339) Receiving objects: 9% (121/1339) Receiving objects: 10% (134/1339) Receiving objects: 11% (148/1339) Receiving objects: 12% (161/1339) Receiving objects: 13% (175/1339) Receiving objects: 14% (188/1339) Receiving objects: 15% (201/1339) Receiving objects: 16% (215/1339) Receiving objects: 17% (228/1339) Receiving objects: 18% (242/1339) Receiving objects: 19% (255/1339) Receiving objects: 20% (268/1339) Receiving objects: 21% (282/1339) Receiving objects: 22% (295/1339) Receiving objects: 23% (308/1339) Receiving objects: 24% (322/1339) Receiving objects: 25% (335/1339) Receiving objects: 26% (349/1339) Receiving objects: 27% (362/1339) Receiving objects: 28% (375/1339) Receiving objects: 29% (389/1339) Receiving objects: 30% (402/1339) Receiving objects: 31% (416/1339) Receiving objects: 32% (429/1339) Receiving objects: 33% (442/1339) Receiving objects: 34% (456/1339) Receiving objects: 35% (469/1339) Receiving objects: 36% (483/1339) Receiving objects: 37% (496/1339) Receiving objects: 38% (509/1339) Receiving objects: 39% (523/1339) Receiving objects: 40% (536/1339) Receiving objects: 41% (549/1339) Receiving objects: 42% (563/1339) Receiving objects: 43% (576/1339) Receiving objects: 44% (590/1339) Receiving objects: 45% (603/1339) Receiving objects: 46% (616/1339) Receiving objects: 47% (630/1339) Receiving objects: 48% (643/1339) Receiving objects: 49% (657/1339) Receiving objects: 50% (670/1339) Receiving objects: 51% (683/1339) Receiving objects: 52% (697/1339) Receiving objects: 53% (710/1339) Receiving objects: 54% (724/1339) Receiving objects: 55% (737/1339) Receiving objects: 56% (750/1339) Receiving objects: 57% (764/1339) Receiving objects: 58% (777/1339) Receiving objects: 59% (791/1339) Receiving objects: 60% (804/1339) Receiving objects: 61% (817/1339) Receiving objects: 62% (831/1339) Receiving objects: 63% (844/1339) Receiving objects: 64% (857/1339) Receiving objects: 65% (871/1339) Receiving objects: 66% (884/1339) Receiving objects: 67% (898/1339) Receiving objects: 68% (911/1339) Receiving objects: 69% (924/1339) Receiving objects: 70% (938/1339) Receiving objects: 71% (951/1339) Receiving objects: 72% (965/1339) Receiving objects: 73% (978/1339) Receiving objects: 74% (991/1339) Receiving objects: 75% (1005/1339) Receiving objects: 76% (1018/1339) Receiving objects: 77% (1032/1339) Receiving objects: 78% (1045/1339) Receiving objects: 79% (1058/1339) Receiving objects: 80% (1072/1339) Receiving objects: 81% (1085/1339) Receiving objects: 82% (1098/1339) remote: Total 1339 (delta 1034), reused 356 (delta 293) Receiving objects: 83% (1112/1339) Receiving objects: 84% (1125/1339) Receiving objects: 85% (1139/1339) Receiving objects: 86% (1152/1339) Receiving objects: 87% (1165/1339) Receiving objects: 88% (1179/1339) Receiving objects: 89% (1192/1339) Receiving objects: 90% (1206/1339) Receiving objects: 91% (1219/1339) Receiving objects: 92% (1232/1339) Receiving objects: 93% (1246/1339) Receiving objects: 94% (1259/1339) Receiving objects: 95% (1273/1339) Receiving objects: 96% (1286/1339) Receiving objects: 97% (1299/1339) Receiving objects: 98% (1313/1339) Receiving objects: 99% (1326/1339) Receiving objects: 100% (1339/1339) Receiving objects: 100% (1339/1339), 194.41 KiB | 754.00 KiB/s, done. Resolving deltas: 0% (0/1034) Resolving deltas: 4% (42/1034) Resolving deltas: 5% (53/1034) Resolving deltas: 6% (64/1034) Resolving deltas: 9% (94/1034) Resolving deltas: 21% (227/1034) Resolving deltas: 22% (229/1034) Resolving deltas: 24% (256/1034) Resolving deltas: 27% (281/1034) Resolving deltas: 28% (292/1034) Resolving deltas: 29% (300/1034) Resolving deltas: 30% (314/1034) Resolving deltas: 32% (334/1034) Resolving deltas: 35% (372/1034) Resolving deltas: 36% (373/1034) Resolving deltas: 37% (385/1034) Resolving deltas: 38% (393/1034) Resolving deltas: 40% (420/1034) Resolving deltas: 41% (426/1034) Resolving deltas: 42% (442/1034) Resolving deltas: 43% (446/1034) Resolving deltas: 44% (465/1034) Resolving deltas: 45% (473/1034) Resolving deltas: 46% (478/1034) Resolving deltas: 47% (489/1034) Resolving deltas: 48% (497/1034) Resolving deltas: 49% (507/1034) Resolving deltas: 54% (560/1034) Resolving deltas: 55% (573/1034) Resolving deltas: 56% (580/1034) Resolving deltas: 59% (611/1034) Resolving deltas: 60% (621/1034) Resolving deltas: 61% (631/1034) Resolving deltas: 62% (650/1034) Resolving deltas: 63% (652/1034) Resolving deltas: 64% (664/1034) Resolving deltas: 65% (675/1034) Resolving deltas: 69% (717/1034) Resolving deltas: 70% (731/1034) Resolving deltas: 71% (736/1034) Resolving deltas: 72% (745/1034) Resolving deltas: 73% (756/1034) Resolving deltas: 74% (766/1034) Resolving deltas: 75% (776/1034) Resolving deltas: 77% (797/1034) Resolving deltas: 78% (808/1034) Resolving deltas: 79% (818/1034) Resolving deltas: 80% (828/1034) Resolving deltas: 81% (838/1034) Resolving deltas: 82% (848/1034) Resolving deltas: 83% (861/1034) Resolving deltas: 84% (869/1034) Resolving deltas: 85% (879/1034) Resolving deltas: 86% (890/1034) Resolving deltas: 87% (905/1034) Resolving deltas: 88% (912/1034) Resolving deltas: 89% (921/1034) Resolving deltas: 90% (931/1034) Resolving deltas: 91% (946/1034) Resolving deltas: 92% (953/1034) Resolving deltas: 93% (963/1034) Resolving deltas: 94% (978/1034) Resolving deltas: 95% (988/1034) Resolving deltas: 96% (994/1034) Resolving deltas: 97% (1004/1034) Resolving deltas: 98% (1014/1034) Resolving deltas: 99% (1024/1034) Resolving deltas: 100% (1034/1034) Resolving deltas: 100% (1034/1034), completed with 223 local objects. From https://git.launchpad.net/epics-base 7c168f20f..a24956167 3.15 -> origin/3.15 7cb80d5a1..0f8ea3aa3 7.0 -> origin/7.0 * [new tag] R7.0.7 -> R7.0.7 Fetching submodule .ci From https://github.com/epics-base/ci-scripts 93062ba..aea7906 master -> origin/master * [new tag] v3.3.0-10-g8a2666a -> v3.3.0-10-g8a2666a * [new tag] v3.4.0 -> v3.4.0 Fetching submodule modules/pvAccess From https://github.com/epics-base/pvAccessCPP c63d073..81d79ec master -> origin/master * [new tag] 7.1.6 -> 7.1.6 Fetching submodule modules/pvData From https://github.com/epics-base/pvDataCPP d3b4976..45671fa master -> origin/master * [new tag] 8.0.5 -> 8.0.5 Could not access submodule '.ci'Fetching submodule modules/pvDatabase From https://github.com/epics-base/pvDatabaseCPP 05d54c6..1b787c5 master -> origin/master * [new tag] 4.7.0 -> 4.7.0 Fetching submodule modules/pva2pva From https://github.com/epics-base/pva2pva f07d14b..1c7846f master -> origin/master * [new tag] 1.4.0 -> 1.4.0 at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2697) at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2111) at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:87) at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:623) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:158) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:151) at hudson.remoting.UserRequest.perform(UserRequest.java:211) at hudson.remoting.UserRequest.perform(UserRequest.java:54) at hudson.remoting.Request$2.run(Request.java:376) at hudson.remoting.InterceptingExecutorService.lambda$wrap$0(InterceptingExecutorService.java:78) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to mac-1 at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1784) at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:356) at hudson.remoting.Channel.call(Channel.java:1000) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:143) at sun.reflect.GeneratedMethodAccessor912.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:129) at com.sun.proxy.$Proxy78.execute(Unknown Source) at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1004) at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1248) at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1312) at hudson.scm.SCM.checkout(SCM.java:540) at hudson.model.AbstractProject.checkout(AbstractProject.java:1217) at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:647) at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:85) at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:519) at hudson.model.Run.execute(Run.java:1897) at hudson.matrix.MatrixRun.run(MatrixRun.java:153) at hudson.model.ResourceController.execute(ResourceController.java:101) at hudson.model.Executor.run(Executor.java:442) ERROR: Error fetching remote repo 'origin' TAP Reports Processing: START Looking for TAP results report in workspace using pattern: **/O.*/*.tap Did not find any matching files. Notifying upstream projects of job completion Email was triggered for: Failure - Any Sending email for trigger: Failure - Any Sending email to: core-talk at aps.anl.gov
| ANJ, 07 Oct 2022 |
Home
News
About
Talk
Base
Modules
Extensions
