2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: [Bug 1991765] Re: Problem with ROFF change in ai/ao
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 06 Oct 2022 19:50:41 -0000
Hmm… We have a driver that sets ROFF to -512. I’ll need to see how I can modify it. My first attempt was to simply use EOFF instead (properly scaled of course) but that does not work with breakpoint tables. Another case was a user who had set ROFF to a negative value in his template or from another record or something like that (with another driver which does not use ROFF).
I guess we cannot have both, full 32 bit unsigned AND negative values unless ROFF was a double (or 64 bit signed int).
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1991765
Title:
Status in EPICS Base:
  New
Bug description:
  In commit ffcbd4ca, ROFF of ai and ao have been changed from LONG to ULONG.
  This has caused problems when migrating from EPICS 3.14 to 7.0 in multiple cases where ROFF was negative and thus became a huge positive value.
  There seems to be no workaround for this regression.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1991765/+subscriptions
[Bug 1991765] [NEW] Problem with ROFF change in ai/ao Dirk Zimoch via Core-talk
Prev: [Bug 1991765] Re: Problem with ROFF change in ai/ao Andrew Johnson via Core-talk
Next: Re: [Bug 1991765] Re: Problem with ROFF change in ai/ao Simon Rose via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: [Bug 1991765] Re: Problem with ROFF change in ai/ao Simon Rose via Core-talk
Next: epics-7.0 » mac - Build # 433 - Failure! APS Jenkins via Core-talk
ANJ, 07 Oct 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
