Hi all -
Is there some document with more information about this field and the motivation behind the conversion performed? I have to admit that it really isn't obvious to me why the field should not be allowed to be negative. It would also be nice to see what is a use-case that it is solving; the conversion
VAL = ((RVAL + ROFF) * ASLO + AOFF) * ESLO + EOFF)
seems pretty arbitrary.
I looked back at some of the older threads about this, and the history is also somewhat unclear to me, with it being deprecated, then undeprecated, etc; it would be nice to see some documentation as to _why_ it is the way it is at the moment.
Cheers,
Simon
On 2022-10-06, 19:20, "Core-talk on behalf of Andrew Johnson via Core-talk" <core-talk-bounces at aps.anl.gov on behalf of core-talk at aps.anl.gov> wrote:
The original change (released 7½ years ago) was to properly support
32-bit raw values as you requested in https://epics.anl.gov/tech-
talk/2013/msg00684.php but without triggering UB, which modern compiler
optimizers love to rely on to break previously-working-but-non-portable
code.
ROFF can't hold negative values, it was designed to support ADCs and
DACs with an offset zero. If you have device support that was setting a
negative ROFF it was depending on overflowing a uint32 calculation,
which gcc allows with the -fwrapv flag but EPICS doesn't set that and it
isn't portable.
I don't think we can change this in the record types at all, the device
support has to provide any fixes necessary IMHO.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1991765
Title:
Problem with ROFF change in ai/ao
Status in EPICS Base:
New
Bug description:
In commit ffcbd4ca, ROFF of ai and ao have been changed from LONG to ULONG.
This has caused problems when migrating from EPICS 3.14 to 7.0 in multiple cases where ROFF was negative and thus became a huge positive value.
There seems to be no workaround for this regression.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1991765/+subscriptions
- [Bug 1991765] [NEW] Problem with ROFF change in ai/ao Dirk Zimoch via Core-talk
- [Bug 1991765] Re: Problem with ROFF change in ai/ao Andrew Johnson via Core-talk
[Bug 1991765] Re: Problem with ROFF change in ai/ao Dirk Zimoch via Core-talk
epics-7.0 » mac - Build # 433 - Failure! APS Jenkins via Core-talk
<2022>
2025
2026
<2022>
2025
2026
