On 5/4/23 08:30, Michael Davidsaver wrote:
On 5/4/23 08:23, Mark Rivers wrote:
Hi Andrew,
I looked to see how PREC and other fields support DBE_PROPERTY in EPICS base. I see that the ao, ai, etc. record dbd files put the attribute "prop(YES)" on fields that should generate DBE_PROPERTY callbacks.
I just added prop(YES) to the PREC field in motorRecord.dbd and now when PREC changes Phoebus updates the window to the new precision instantly, without needing to close and re-open the window. This is great!
A couple of questions:
- If we were to add prop(YES) to fields in the motor record then it would require a minimum of base 3.14.11?
It would actually be >= 3.15.0.2
https://github.com/epics-base/epics-base/commit/3cccdd813458936b536f51589a100cfcfd91f637
My mistake. This commit adds "prop(YES)" to the base .dbd files.
The C .dbd file parser has always ignored unknown recordtype "items".
(cf. dbRecordtypeFieldItem() ) so I think any 3.14 would ignore "prop(YES)".
- RE: OPI updates when enum strings/values change Mark Rivers via Core-talk
- OPI updates when enum strings/values change Mark Rivers via Core-talk
- Re: OPI updates when enum strings/values change Andrew Johnson via Core-talk
- Re: OPI updates when enum strings/values change Michael Davidsaver via Core-talk
<2023>
2025
2026
<2023>
2025
2026
