2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: pC_->doCallbacksEnum() coming too early
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>, Torsten Bögershausen <tboegi at edom.se>
Date: Thu, 29 Feb 2024 14:09:56 +0000
Torsten, If you only have 20 motors with 1-2 enums then I don't understand why you don't just use the current "correct" solution which does not require a hack to do callbacks. Just implement the readEnum method. This is a search for
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Torsten,
This is a search for all current synApps and areaDetector drivers that do that:
(base) [epics@corvette devel]$ find . -name '*.cpp' -exec grep -H readEnum {} \;
./Galil/3-6/GalilSup/src/GalilController.cpp:asynStatus GalilController::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[], size_t nElements, size_t *nIn)
./asyn-4-43/testAsynPortDriverApp/src/testAsynPortDriver.cpp:asynStatus testAsynPortDriver::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[], size_t nElements, size_t *nIn)
./asyn-4-43/testErrorsApp/src/testErrors.cpp:asynStatus testErrors::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[], size_t nElements, size_t *nIn)
./quadEM-9-4/quadEMApp/src/drvPCR4.cpp:asynStatus drvPCR4::readEnum(asynUser *pasynUser,
./pmac-2-5-13/pmacApp/src/pmacController.cpp:pmacController::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
./measComp-4-0/measCompApp/src/drvMultiFunction.cpp:asynStatus MultiFunction::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[], size_t nElements, size_t *nIn)
../labjack/LabJackApp/src/LabJackDriver.cpp:asynStatus LabJackDriver::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[], size_t nElements, size_t *nIn)
./areaDetector-3-13/ADAndor3/andor3App/src/andor3.cpp:asynStatus andor3::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
./areaDetector-3-13/ADDexela/dexelaApp/src/Dexela.cpp:asynStatus Dexela::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
./areaDetector-3-13/ADPSL/pslApp/src/PSL.cpp:asynStatus PSL::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
./areaDetector-3-13/ADPointGrey/pointGreyApp/src/pointGrey.cpp:asynStatus pointGrey::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
./areaDetector-3-13/ADmarCCD/marCCDApp/src/marCCD.cpp:asynStatus marCCD::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
../areaDetector-3-13/ADPICam/PICamApp/src/ADPICam.cpp:asynStatus ADPICam::readEnum(asynUser *pasynUser, char *strings[], int values[],
./areaDetector-3-13/ADAndor/andorApp/src/andorCCD.cpp:asynStatus AndorCCD::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
./areaDetector-3-13/ADLightField/lightFieldApp/src/LightField.cpp:asynStatus LightField::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
./areaDetector-3-13/ADQImaging/App/src/QImaging.cpp:asynStatus QImage::readEnum(asynUser *pasynUser,
./areaDetector-3-13/ADPylon/pylonApp/src/ADPylon.cpp:asynStatus ADPylon::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
./areaDetector-3-13/ADSpinnaker/spinnakerApp/src/ADSpinnaker.cpp:asynStatus ADSpinnaker::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
./areaDetector-3-13/aravisGigE/aravisGigEApp/src/aravisCamera.cpp:asynStatus aravisCamera::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
../areaDetector-3-13/ADVimba/vimbaApp/src/ADVimba.cpp:asynStatus ADVimba::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
../areaDetector-3-13/ADGenICam/GenICamApp/src/ADGenICam.cpp:asynStatus ADGenICam::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
./areaDetector-3-13/specsAnalyser/specsAnalyserApp/src/specsAnalyser.cpp:asynStatus SpecsAnalyser::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[], size_t nElements, size_t *nIn)
From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov>
Sent: Wednesday, February 28, 2024 11:20 PM
To: Ralph Lange <ralph.lange at gmx.de>; EPICS Core Talk <core-talk at aps.anl.gov>
Hej Experts, thanks so much for the help. Right now I have a somewhat hackish version. #if 0 /* This version gives: warning: 'rset' is deprecated [-Wdeprecated-declarations] rset *prset; */ #include <dbAccess.h> /* interruptAccept */ #else #include <dbCoreAPI.h> DBCORE_API extern volatile int interruptAccept; #endif But it works well. Ralhp, I think that I do what you suggest already. When connecting to the PLC, all data is read as fast as possible. However, we are talking about 20 motors, which have 1--2 enums. Not Megabytes of data ;-) All this enum-values (for the mbbi) are today already stored in a bunch of asyn-parameters. So it was "only" the determination, when is it a good time for the callback, that was missing. Thanks again. On 2024-02-28 09:53, Ralph Lange via Core-talk wrote: > My 2cts. . . On Tue, 27 Feb 2024 at 23: 51, Mark Rivers via Core-talk > <core-talk@ aps. anl. gov> wrote:   ZjQcmQRYFpfptBannerEnd Hi Torsten, > Ø  The PLC gives us some names for enmums, resulting in a call to Ø > pC_->doCallbacksEnum()   doCallbacksEnum() > ZjQcmQRYFpfptBannerStart > This Message Is From an External Sender > This message came from outside your organization. > ZjQcmQRYFpfptBannerEnd > My 2cts... > > On Tue, 27 Feb 2024 at 23:51, Mark Rivers via Core-talk > <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote: > > __ > ZjQcmQRYFpfptBannerEnd > > Hi Torsten,____ > > __ __ > > __Ø__The PLC gives us some names for enmums, resulting in a call to____ > > __Ø__pC_->doCallbacksEnum()____ > > __ __ > > doCallbacksEnum() is only intended to be called when an enum value > changes at run-time, i.e. after iocInit.  For enums that the driver > determines at initialization you should simply implement the > asynPortDriver::readEnum() method.  Device support will call your > driver during iocInit to read the enum values/strings/severities for > all records with enum VAL fields.____ > > __ __ > > testAsynPortDriver has an example here:____ > > https://urldefense.us/v3/__https://github.com/epics-modules/asyn/blob/a94a78987a99b1c36bbd641a67341069dc5d627e/testAsynPortDriverApp/src/testAsynPortDriver.cpp*L340__;Iw!!G_uCfscf7eWS!cNPFGdiAvPevZU44dGFiDBVJDU6UCKIHT814ujg1PMT3Y6IUhS7efeCJLa1uEeA5WaHYqwsTz0fMuYpskNU$ <https://urldefense.us/v3/__https://github.com/epics-modules/asyn/blob/a94a78987a99b1c36bbd641a67341069dc5d627e/testAsynPortDriverApp/src/testAsynPortDriver.cpp*L340__;Iw!!G_uCfscf7eWS!fE_LD5q32_jjj9Y2BpELUbcw3yXiB5OnxyWCR4yUcD48lMAvhT1_A34lEQ5JZaBnQaPIH8NUbIHoKoZgjJ-Vp9EB5zY$>____ > > __ __ > > It also has an example of using doCallbacksEnum(), which it does > when the vertical gain is changed at run time.____ > > https://urldefense.us/v3/__https://github.com/epics-modules/asyn/blob/a94a78987a99b1c36bbd641a67341069dc5d627e/testAsynPortDriverApp/src/testAsynPortDriver.cpp*L374__;Iw!!G_uCfscf7eWS!cNPFGdiAvPevZU44dGFiDBVJDU6UCKIHT814ujg1PMT3Y6IUhS7efeCJLa1uEeA5WaHYqwsTz0fM2ymOgHM$ <https://urldefense.us/v3/__https://github.com/epics-modules/asyn/blob/a94a78987a99b1c36bbd641a67341069dc5d627e/testAsynPortDriverApp/src/testAsynPortDriver.cpp*L374__;Iw!!G_uCfscf7eWS!fE_LD5q32_jjj9Y2BpELUbcw3yXiB5OnxyWCR4yUcD48lMAvhT1_A34lEQ5JZaBnQaPIH8NUbIHoKoZgjJ-VnvkyVf8$> > > > Been there... > The problem is that these are synchronous (blocking) calls. If you have > many devices and/or devices that are handled asynchronously, this is > likely to screw up your IOC startup. > > I think the most reasonable way to handle the situation is a bit more > complex: > > * from the driver, do the requests to the devices as early as possible > after the devices are up (and do the requests in parallel), > * when the responses come in, queue them, > * start the worker thread(s) for the queues (that push the values into > the database) when the IOC is fully up, through the interruptAccept > initHook. > > That will work no matter if the IOC becomes ready before, during or > after the initial device readout is finished. > Queueing incoming responses is always a good idea that helps with bursts > or high-load-on-the-IOC-host situations. > > Cheers, > ~Ralph
Re: pC_->doCallbacksEnum() coming too early Ralph Lange via Core-talk
pC_->doCallbacksEnum() coming too early Torsten Bögershausen via Core-talk
Re: pC_->doCallbacksEnum() coming too early Johnson, Andrew N. via Core-talk
RE: pC_->doCallbacksEnum() coming too early Mark Rivers via Core-talk
Re: pC_->doCallbacksEnum() coming too early Torsten Bögershausen via Core-talk
Prev: Re: pC_->doCallbacksEnum() coming too early Torsten Bögershausen via Core-talk
Next: Re: pC_->doCallbacksEnum() coming too early Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
ANJ, 29 Feb 2024 · Home · News · About · Talk · Base · Modules · Extensions ·
