On 4/17/25 08:13, Johnson, Andrew N. wrote:
On 4/17/25, 9:27 AM, "Michael Davidsaver" <mdavidsaver at gmail.com> wrote:
On 4/16/25 09:34, Johnson, Andrew N. via Core-talk wrote:
I saw that a new Fedora was release very recently.
Yes. Now comes GCC 15, which defaults to C23.
... Ah that wasn’t a PR, and your Fedora CI job did fail,
I noticed this first failure during a PVXS build, and made a quick fix
hoping that this would be the only issue. No such luck...
but apparently we don’t get notifications when non-PR jobs fail. Can/should we change that in the CI?
Not that I know of, but GHA gets new options all the time.
Looking at the specific code that’s failing, in this case I think the fix is just adding a cast to DEVSUPFUN* since we only print the pointer. I just pushed a commit to try that, this job <https://urldefense.us/v3/__https://github.com/anjohnson/epics-base/actions/runs/14518774891/job/40734270393__;!!G_uCfscf7eWS!YKyfLVxvUKjYx8LCX8RI-WiIX1CKZ5bUoMMzS3H6vMYXVj-TVwZFzSGpU9sc6AXT_hLKRr6tBE-PO5ZYnEDCtYeyPQ$ > shows that seemed to work <https://urldefense.us/v3/__https://github.com/anjohnson/epics-base/actions/runs/14518774891/job/40734270393*step:8:4731__;Iw!!G_uCfscf7eWS!YKyfLVxvUKjYx8LCX8RI-WiIX1CKZ5bUoMMzS3H6vMYXVj-TVwZFzSGpU9sc6AXT_hLKRr6tBE-PO5ZYnECnboF3HA$ >, but there are other similar failures later in the build <https://urldefense.us/v3/__https://github.com/anjohnson/epics-base/actions/runs/14518774891/job/40734270393*step:8:6704__;Iw!!G_uCfscf7eWS!YKyfLVxvUKjYx8LCX8RI-WiIX1CKZ5bUoMMzS3H6vMYXVj-TVwZFzSGpU9sc6AXT_hLKRr6tBE-PO5ZYnEBPdWAjWg$ >, which I will look at.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Did the "Fedora-latest" version on GitHub just get bumped? Johnson, Andrew N. via Core-talk
- Re: Did the "Fedora-latest" version on GitHub just get bumped? Michael Davidsaver via Core-talk
- Re: Did the "Fedora-latest" version on GitHub just get bumped? Johnson, Andrew N. via Core-talk
RE: Did the "Fedora-latest" version on GitHub just get bumped? Zimoch Dirk via Core-talk
<2025>
2026
<2025>
2026
