2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Did the "Fedora-latest" version on GitHub just get bumped?
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Thu, 17 Apr 2025 15:13:36 +0000
On 4/17/25, 9:27AM, "Michael Davidsaver" <mdavidsaver at gmail.com> wrote:
On 4/16/25 09:34, Johnson, Andrew N. via Core-talk wrote:
> I saw that a new Fedora was release very recently.
Yes.  Now comes GCC 15, which defaults to C23.
https://urldefense.us/v3/__https://github.com/epics-base/epics-base/issues/632__;!!G_uCfscf7eWS!YHkjFuvcJ3O3DLlrIx18bZ_np7W9OljZ-htT9LK3F3Dz-HpgmTBbEFU6MZqA-7ka1WLkntrENxJ-_pt2$
I saw that commit, how come the build didn’t fail with the same error that other PRs are? Ah that wasn’t a PR, and your Fedora CI job did fail, but apparently we don’t get notifications when non-PR jobs fail. Can/should we change that in the CI?
Looking at the specific code that’s failing, in this case I think the fix is just adding a cast to DEVSUPFUN* since we only print the pointer. I just pushed a commit to try that, this job shows that seemed to work, but there are other similar failures later in the build, which I will look at.
- Andrew
Complexity comes for free, Simplicity you have to work for.
RE: Did the "Fedora-latest" version on GitHub just get bumped? Zimoch Dirk via Core-talk
Re: Did the "Fedora-latest" version on GitHub just get bumped? Michael Davidsaver via Core-talk
Did the "Fedora-latest" version on GitHub just get bumped? Johnson, Andrew N. via Core-talk
Prev: Re: Did the "Fedora-latest" version on GitHub just get bumped? Michael Davidsaver via Core-talk
Next: RE: Did the "Fedora-latest" version on GitHub just get bumped? Zimoch Dirk via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
ANJ, 17 Apr 2025 · Home · News · About · Talk · Base · Modules · Extensions ·
