2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: pvput JSON syntax
From: Ralph Lange via Core-talk <[email protected]>
To: EPICS Core Talk <[email protected]>
Date: Thu, 16 Jan 2020 13:51:13 +0100
On Thu, 16 Jan 2020 at 13:22, Michael Davidsaver <[email protected]> wrote:
On Thu, Jan 16, 2020, 4:16 AM Ralph Lange via Core-talk <[email protected]> wrote:
Interesting...
How does your pvput get anything starting with an "{" around the check at
Can you show what's happening when you run the command from the usage message, i.e.
pvput double01 {"value":1.234}
The "JSON support is present" line in "-h" output is printed unconditionally.
Yes, now that Base >=3.15 is required I removed the conditional.
What am I doing wrong trying to use it, then?!
~Ralph
Re: pvput JSON syntax Michael Davidsaver via Core-talk
pvput JSON syntax Ralph Lange via Core-talk
Re: pvput JSON syntax Timo Korhonen via Core-talk
Re: pvput JSON syntax Ralph Lange via Core-talk
Prev: Re: pvput JSON syntax Michael Davidsaver via Core-talk
Next: Re: pvput JSON syntax Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 16 Jan 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
