2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: pvput JSON syntax
From: Michael Davidsaver via Core-talk <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Core Talk <[email protected]>
Date: Thu, 16 Jan 2020 06:11:28 -0800
On 1/16/20 4:51 AM, Ralph Lange via Core-talk wrote:
> On Thu, 16 Jan 2020 at 13:22, Michael Davidsaver <[email protected] <mailto:[email protected]>> wrote:
>     On Thu, Jan 16, 2020, 4:16 AM Ralph Lange via Core-talk <[email protected] <mailto:[email protected]>> wrote:
>         Interesting...
>         How does your pvput get anything starting with an "{" around the check at
>         https://github.com/epics-base/pvAccessCPP/blob/master/pvtoolsSrc/pvput.cpp#L339 ;
>         Can you show what's happening when you run the command from the usage message, i.e.
>             pvput double01 {"value":1.234}
>         The "JSON support is present" line in "-h" output is printed unconditionally.
>     Yes, now that Base >=3.15 is required I removed the conditional.
> What am I doing wrong trying to use it, then?!
This was prior to 7.0.3.1.  The conditionals were present in 7.0.2
https://github.com/epics-base/pvAccessCPP/commit/50de6cc58ef3830e77280274fea769a66b1d46c9
Attachment: signature.asc
Description: OpenPGP digital signature
Re: pvput JSON syntax Ralph Lange via Core-talk
Re: pvput JSON syntax Timo Korhonen via Core-talk
Re: pvput JSON syntax Michael Davidsaver via Core-talk
Prev: Re: pvput JSON syntax Ralph Lange via Core-talk
Next: Re: pvput JSON syntax Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 16 Jan 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
