2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Appveyor Settings for the 3.15 (and 7.0) branch builds
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Sat, 26 Dec 2020 16:15:58 +0100
Hi Andrew,
On Wed, 23 Dec 2020 at 19:42, Johnson, Andrew N. <anj at anl.gov> wrote:
I just set “Custom configuration .yml file name” to empty in the epics-base-3 project UI, and it subsequently picked up and used a change I then committed to the file on the 3.15 branch! The doc’s say that the filename “.appveyor.yml” is supported as is, and apparently leaving it blank made it do the right thing (we still have the “branches/only” whitelist in the file, I also added the regex /R3\.15\.\d+.*/ to that).
That was the original state and didn't work as expected when I tested it a few weeks ago.
Note that the important point is that the epics-base-3 project should *not* build commits to the 7.0 branch and vice versa. For me, it was always all projects building all branches - unless I was using the gists.
Good luck!
~Ralph
Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Johnson, Andrew N. via Core-talk
Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Ralph Lange via Core-talk
Prev: Jenkins build is back to normal : epics-base-7.0-win64 #170 APS Jenkins via Core-talk
Next: Re: How to "tweak" tests? Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Johnson, Andrew N. via Core-talk
Next: Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Johnson, Andrew N. via Core-talk
ANJ, 28 Dec 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
