2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Appveyor Settings for the 3.15 (and 7.0) branch builds
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 28 Dec 2020 22:34:07 +0000
On Dec 26, 2020, at 9:15 AM, Ralph Lange via Core-talk <core-talk at aps.anl.gov> wrote:
On Wed, 23 Dec 2020 at 19:42, Johnson, Andrew N. <anj at anl.gov> wrote:
I just set “Custom configuration .yml file name” to empty in the epics-base-3 project UI, and it subsequently picked up and used a change I then committed to the file on the 3.15 branch! The doc’s say that the filename “.appveyor.yml” is supported as is, and apparently leaving it blank made it do the right thing (we still have the “branches/only” whitelist in the file, I also added the regex /R3\.15\.\d+.*/ to that).
That was the original state and didn't work as expected when I tested it a few weeks ago.
Note that the important point is that the epics-base-3 project should *not* build commits to the 7.0 branch and vice versa. For me, it was always all projects building all branches - unless I was using the gists.
Aargh, and of course I didn’t check the epics-base-3 account after pushing the 7 change…
I have just followed Michael’s suggestion and renamed the file, although without really thinking about how to handle pull requests. The epics-base-3 account should now only build branches that have a file named .appveyor/epics-base-3.yml and the epics-base-7 branch uses .appveyor/epics-base-7.yml so the filename in the new .appveyor directory matches the account it configures. The 3.15 branch is building now; I’m about the push the 7.0 branch to match.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Johnson, Andrew N. via Core-talk
Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Ralph Lange via Core-talk
Prev: Jenkins build is back to stable : epics-base-3.15-test #212 APS Jenkins via Core-talk
Next: Build completed: EPICS Base 7 base-7.0-115 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Prev: Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Ralph Lange via Core-talk
Next: Re: Appveyor Settings for the 3.15 (and 7.0) branch builds Johnson, Andrew N. via Core-talk
ANJ, 29 Dec 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
