2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: CaSe-IndepeDent Menu SEARches?
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Fri, 5 Feb 2021 09:07:54 -0800
On 2/4/21 10:52 AM, Michael Davidsaver wrote:
> On 2/3/21 5:23 PM, Michael Davidsaver wrote:
>> How about improving the error message by printing the choices list from
>> dbPutString() in a way which invites copy+paste?
>>> Can't set "foo.SCAN" to "10 seconds" Extraneous characters
>>> Error at or before ")" in path "."  file "badchoice.db" line 2
>>> dbLoadRecords: failed to load 'badchoice.db'
>>> Error: Failed to load: badchoice.db
>> might become
> Ok, this is the best I have time for today.  Not perfect, as you can see
> it gets my "Pensive" wrong.  Maybe someone knows a better similarity algorithm?
> https://github.com/epics-base/epics-base/pull/104
After investigation a little more.  aka. reading https://en.wikipedia.org/wiki/Edit_distance
I found https://en.wikipedia.org/wiki/Levenshtein_distance which seems to work much better.
Now I think the "Did you mean" suggestions should be reasonably useful, while only adding one
line of output.
Does this seem like a reasonable compromise in terms of SNR?
> Can't set "bar.DTYP" to "Soft Chanel" Not devsup for ai : No digits to convert
>     Did you mean "Soft Channel"?
> Can't set "baz.IVOA" to "Set output To IVOV" using menuIvoa.dbd : No digits to convert
>     Did you mean "Set output to IVOV"?
Re: CaSe-IndepeDent Menu SEARches? Ralph Lange via Core-talk
CaSe-IndepeDent Menu SEARches? Johnson, Andrew N. via Core-talk
Re: CaSe-IndepeDent Menu SEARches? Michael Davidsaver via Core-talk
Prev: Re: iocsh scripts and not using $PWD Michael Davidsaver via Core-talk
Next: Re: CaSe-IndepeDent Menu SEARches? Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: CaSe-IndepeDent Menu SEARches? Michael Davidsaver via Core-talk
ANJ, 05 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
