2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: CaSe-IndepeDent Menu SEARches?
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 5 Feb 2021 18:16:48 +0100
On Fri, 5 Feb 2021 at 18:08, Michael Davidsaver via Core-talk <core-talk at aps.anl.gov> wrote:
After investigation a little more.  aka. reading https://en.wikipedia.org/wiki/Edit_distance
I found https://en.wikipedia.org/wiki/Levenshtein_distance which seems to work much better.
Now I think the "Did you mean" suggestions should be reasonably useful, while only adding one
line of output.
Does this seem like a reasonable compromise in terms of SNR?
Perfect!
CaSe-IndepeDent Menu SEARches? Johnson, Andrew N. via Core-talk
Re: CaSe-IndepeDent Menu SEARches? Michael Davidsaver via Core-talk
Prev: Re: CaSe-IndepeDent Menu SEARches? Michael Davidsaver via Core-talk
Next: epics-7.0 - Build # 287 - Unstable! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: CaSe-IndepeDent Menu SEARches? Torsten Bögershausen via Core-talk
ANJ, 05 Feb 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
