2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: failing tests on github.com
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Fri, 16 Apr 2021 10:59:58 +0000
Today I pushed a merge request which caused several tests to fail at locations which are unrelated to my change.
https://github.com/dirk-zimoch/epics-base/actions/runs/754804587
Is there something wrong with the test setup? Is the current 7.0 head OK?
Dirk
Re: failing tests on github.com Ben Franksen via Core-talk
Re: failing tests on github.com Ralph Lange via Core-talk
Prev: Re: [EXTERNAL] Windows paths inside iocShell Johnson, Andrew N. via Core-talk
Next: Re: failing tests on github.com Ben Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Windows paths inside iocShell Ralph Lange via Core-talk
ANJ, 18 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
