2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: failing tests on github.com
From: Ben Franksen via Core-talk <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>, "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Fri, 16 Apr 2021 14:29:12 +0200
Am 16.04.21 um 12:59 schrieb Zimoch Dirk (PSI) via Core-talk:
> Today I pushed a merge request which caused several tests to fail at locations which are unrelated to my change.
> https://github.com/dirk-zimoch/epics-base/actions/runs/754804587
> Is there something wrong with the test setup? Is the current 7.0 head OK?
This came up in the recent meeting... the notes merely quote MAD as
stating "We should document the tests that are regularly failing,
suggest adding a GH issue for this." My preference would be to fix them
(either our code, or the tests if the latter are at fault) but I have no
idea how to do that.
Cheers
Ben
I would rather have questions that cannot be answered, than answers that
cannot be questioned.  -- Richard Feynman
Attachment: signature.asc
Description: OpenPGP digital signature
AW: failing tests on github.com Zimoch Dirk (PSI) via Core-talk
Re: failing tests on github.com Michael Davidsaver via Core-talk
Prev: failing tests on github.com Zimoch Dirk (PSI) via Core-talk
Next: AW: failing tests on github.com Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
ANJ, 20 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
