2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: failing tests on github.com
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Ben Franksen <benjamin.franksen at helmholtz-berlin.de>, "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>, "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Tue, 20 Apr 2021 09:27:02 -0700
On 4/16/21 5:29 AM, Ben Franksen via Core-talk wrote:
> ...This came up in the recent meeting... the notes merely quote MAD as
> stating "We should document the tests that are regularly failing,
> suggest adding a GH issue for this." ...
I've created a "discussion" instead of an "issue" with the idea that
threading might make it easier to manage which are likely to be
a number of unrelated reports.
https://github.com/epics-base/epics-base/discussions/162
failing tests on github.com Zimoch Dirk (PSI) via Core-talk
Re: failing tests on github.com Ben Franksen via Core-talk
Prev: Jenkins build is back to normal : 3.15-example-win64 #242 APS Jenkins via Core-talk
Next: epics-7.0 » linux32 - Build # 328 - Fixed! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: failing tests on github.com J. Lewis Muir via Core-talk
Next: Re: failing tests on github.com Ralph Lange via Core-talk
ANJ, 20 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
