2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Windows paths inside iocShell
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Wed, 14 Apr 2021 18:45:45 +0000
On Apr 14, 2021, at 12:32 PM, Ralph Lange via Core-talk <core-talk at aps.anl.gov> wrote:
>> Do we need some syntax in macros to prevent them from escaping back-slashes when expanding values?  I’m not sure how easy it would be to implement that, but it might be possible. Any other suggestions on what might be changed?
> Looking at the macLib code, I was getting the expression that the original intention might have been to do it right.
>     /* discard quotes and escapes if level is > 0 (i.e. if these aren't
>        the user's quotes and escapes) */
> Or not? (Shouldn't quotes and escapes only be discarded when they are the user's, and kept through replacements?)
> Well, at least there was an intention.
Read the macLibNOTES file in the libCom/macLib directory. Unfortunately it’s a bit self-referential in places as it was originally meant to be run on itself so not always immediately obvious.
> What if using a variable wouldn't change its content? After the second line, I would expect PP and QQ to be the same.
> epics> epicsEnvSet PP a\\b\\c
> epics> epicsEnvSet QQ $(PP)
> epics> epicsEnvShow
> PP=a\b\c
> QQ=abc
> We could maybe add another bracket character pair for verbatim usage.
> epics> echo $[eeed]
> I am afraid that changing the current behaviour - even if it was "correcting" it - would add a pretty high risk of breaking things for users.
I agree, I wouldn’t do that; I was thinking of something more on the lines of ${\PP} or ${'PP'} which both currently return the same as ${PP}. I’d rather not add more start/end character pairs to the macro syntax. What would be simplest depends on whether I can detect the modifiers in the right place inside the code, the leading back-slash might be simplest to implement. We'd have to be careful about how to expand things like ${\${PP}=${Q}} though.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: [EXTERNAL] Windows paths inside iocShell Ralph Lange via Core-talk
Re: [EXTERNAL] Windows paths inside iocShell Kasemir, Kay via Core-talk
Re: [EXTERNAL] Windows paths inside iocShell Johnson, Andrew N. via Core-talk
Prev: Re: [EXTERNAL] Windows paths inside iocShell Ralph Lange via Core-talk
Next: failing tests on github.com Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: [EXTERNAL] Windows paths inside iocShell Ralph Lange via Core-talk
ANJ, 18 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
