2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: failing tests on github.com
From: Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 16 Apr 2021 15:38:45 +0200
On 4/16/21 3:33 PM, Ralph Lange via Core-talk wrote:
On Fri, 16 Apr 2021 at 13:36, Zimoch Dirk (PSI) via Core-talk <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
    Today I pushed a merge request which caused several tests to fail at
    locations which are unrelated to my change.
    https://github.com/dirk-zimoch/epics-base/actions/runs/754804587
    <https://github.com/dirk-zimoch/epics-base/actions/runs/754804587>
    Is there something wrong with the test setup? Is the current 7.0
    head OK?
I don't see any failing tests there - what are you referring to?
Cheers,
~Ralph
The status is red for 3 runs: (Ub20), and 2 * win
But all tests passed.
Hmmm
Re: failing tests on github.com Ralph Lange via Core-talk
failing tests on github.com Zimoch Dirk (PSI) via Core-talk
Prev: Re: failing tests on github.com Ralph Lange via Core-talk
Next: Re: failing tests on github.com Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
ANJ, 16 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
