2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: failing tests on github.com
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 16 Apr 2021 15:43:32 +0200
On Fri, 16 Apr 2021 at 15:38, Torsten Bögershausen <torsten.bogershausen at ess.eu> wrote:
On 4/16/21 3:33 PM, Ralph Lange via Core-talk wrote:
> On Fri, 16 Apr 2021 at 13:36, Zimoch Dirk (PSI) via Core-talk
> <core-talk at aps.anl.gov <mailto:core-talk at aps.anl.gov>> wrote:
>     Today I pushed a merge request which caused several tests to fail at
>     locations which are unrelated to my change.
>     https://github.com/dirk-zimoch/epics-base/actions/runs/754804587
>     <https://github.com/dirk-zimoch/epics-base/actions/runs/754804587>
>     Is there something wrong with the test setup? Is the current 7.0
>     head OK?
> I don't see any failing tests there - what are you referring to?
The status is red for 3 runs: (Ub20), and 2 * win
But all tests passed.
These runs get "Timeout".
That's a new feature in the EPICS Build system to solve situations where tests are hanging infinitely.
The timeout period has been set explicitly in the CI configuration of Base to a time that is too short for GitHub Actions.
Cheers,
~Ralph
failing tests on github.com Zimoch Dirk (PSI) via Core-talk
Re: failing tests on github.com Ralph Lange via Core-talk
Re: failing tests on github.com Torsten Bögershausen via Core-talk
Prev: Re: failing tests on github.com Torsten Bögershausen via Core-talk
Next: Re: failing tests on github.com J. Lewis Muir via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Build failed: EPICS Base 7 base-7.0-302 AppVeyor via Core-talk
ANJ, 16 Apr 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
