After retestiong: things looks good.
https://urldefense.us/v3/__https://github.com/epics-base/epics-base/pull/949__;!!G_uCfscf7eWS!eOZntKW7RMSu1wOYVPNvKRJKOamkzgspWqZgnl8RPPZMX4Kv7OBFxbI9kUun_ld2_mhKee23GrsiKI1y-lc$
Should the PR be merged ?
(I probably don't add more comments there)
I think so, because it is an improvement
(and will allow us to switch back to the master branch when fetching
EPICS base in the ci job).
/Torsten
On 2026-08-26 21:20, Torsten Bögershausen via Core-talk wrote:
On 2026-08-26 20:25, Michael Davidsaver wrote:
On 8/26/26 10:25 AM, Torsten Bögershausen wrote:
Thanks for the possible fix.
However:
No good news yet.
I recompiled and quickly run the failed test - It didn't pass
Whatever that means. More digging needed here.
Please update again. I made a silly mistake, which should now be
corrected.
Hm, that looks better (the very test that failed passed now), thanks!
However, some (s)ligth feeling whispers that it may be a good
idea to start to discuss to consider to write automated test cases ?
Have a nice evening
/Torsten
[snip]
- github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Torsten Bögershausen via Core-talk
- Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Simon Rose via Core-talk
- Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Ralph Lange via Core-talk
- Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Torsten Bögershausen via Core-talk
- Re: github ci problem: CAS: forcing disconnect from 127.0.0.1:57020 Michael Davidsaver via Core-talk
2025
<2026>
2025
<2026>
