Subject: |
Reserved operand fault using CA on VMS |
[email protected] (Nick Rees) |
Date: |
Fri, 10 Mar 95 15:47:59 HST |
OK, OK, all you users of CA on VMS ;-). Have you fixed this one before I
embark on a fault finding exercise?
Reserved operand fault at PC=0000AB55, PSL=03C00000
Symbolic stack dump follows
module name routine name line rel PC abs PC
CONVERT ntohd 10008 00000005 0000AB55
CONVERT cvrt_double 8898 00000037 00009B0B
SERVICE cacMsg 8926 0000025B 0000B367
SERVICE post_msg 8730 000001B0 0000B0EC
IOCINF ca_process_tcp 9465 000000B8 00007D3C
IOCINF ca_process_input_queue 9353 0000002D 00007AF9
VMS_DEPEN cac_block_for_io_completion 9419 00000045 00006DB9
ACCESS ca_pend 11275 000001AD 00005EA5
THI_CA thi_wait 5192 00000012 00003E36
FAST_MAIN FAST_MAIN 153 00000075 00003875
The relevant bit of code (which has a comment about a similar problem) is:
9996 /*
9997 * sign must be forced to zero if the exponent is zero to prevent reserved
9998 * operand fault- joh 9-13-90
9999 */
10000 void ntohd(double *pNet, double *pHost)
10001 {
10002 double copyin;
10003 struct mitdbl *pMIT;
10004 struct ieeedbl *pIEEE;
10005 ca_uint32_t *ptmp;
10006 ca_uint32_t tmp;
10007
10008 copyin = *pNet;
10009 pMIT = (struct mitdbl *)pHost;
10010 pIEEE = (struct ieeedbl *)©in;
10011
10012 /*
10013 * Byte swap from net order to host order
10014 */
10015 ptmp = (ca_uint32_t *) pIEEE;
Nick
mice mcgehee
Re: Reserved operand fault using CA on VMS Jeff Hill
<1995>
mice mcgehee
<1995>
