Subject: |
application directories and CVS, GNU make etc |
[email protected] (William Lupton) |
Date: |
Wed, 31 May 95 13:35:03 HST |
Dear all,
I have been working on setting up application directories to work with
CVS, GNU make and as much of the EPICS config stuff as possible. I
thought that it would be worthwhile summarizing and soliciting comment,
especially as others may already be thinking about or doing similar
things. I haven't finished yet and can still change things! It would be
good if the results could get used by more than just us.
Oh. My summary seems to be rather long. Sorry about that.
William
- stop here if bored ------------------------------------------------------
Motivation
1. To use CVS for application directories (not for binary files; should
be able to do a cvs checkout, then execute a script - possibly
automatically - and be ready to go in a fully populated EPICS
application tree)
2. To use GNU make for application directories (and also as much as
possible of the standard EPICS config files)
3. To support working in single standalone application directories and
also larger projects which consist of multiple application
directories (this is the approach that we are taking; there is a natural
hierarchy of sub-systems, each of which corresponds to a separate
application directory: lower-level ones can run standalone and
higher-level ones coordinate the lower-level ones and inherit their
databases, records, displays, sequences and so on).
4. To support making of and referring to named releases (and integration
into the existing Keck scheme for this, but _not_ by adding Keck
specifics to the EPICS stuff)
Approach
1. I started with the LANL sae extension (as modified by Andrew Johnson
of RGO; these mods were fairly minor and do not substantially change
the programmer's view of the directory structure).
2. Originally I had planned to retain getrel unchanged. However I wanted
the application directory to look as like the EPICS tree as possible
and there- fore wanted to use the EPICS O.<arch> convention for
object directories. I also felt that links like "targetfrc30" which
reference "base/bin/frc30" offered little over using the explicit
link. In addition, having top-level links for things like "include"
are problematic, since in the old scheme these refer to EPICS base
directories, whereas I wanted them to refer to application-specific
directories.
3. The result is that I have created a modified getrel which takes a
"-keck" option. Doing "getrel -keck" on an empty directory results
in:
% ls -alR
total 8
drwxr-xr-x 3 512 May 31 12:28 .
drwxr-xr-x 13 1024 May 31 12:22 ..
-rw-r--r-- 1 54 May 31 12:28 .current_rel_hist
lrwxrwxrwx 1 27 May 31 12:28 base -> /usr/local/epics/epics/base
lrwxrwxrwx 1 29 May 31 12:28 config -> /usr/local/epics/epics/config
drwxr-xr-x 2 512 May 31 12:28 data
lrwxrwxrwx 1 33 May 31 12:28 extensions -> /usr/local/epics/epics/extensions
lrwxrwxrwx 1 24 May 31 12:28 vw -> /usr/local/vw/m5.1.1.dcs
data:
total 4
drwxr-xr-x 2 512 May 31 12:28 .
drwxr-xr-x 3 512 May 31 12:28 ..
lrwxrwxrwx 1 26 May 31 12:28 default.dctsdr -> ../base/rec/default.dctsdr
lrwxrwxrwx 1 26 May 31 12:28 default.sdrSum -> ../base/rec/default.sdrSum
4. A few things are worthy of comment. Firstly the directory contains
base, config and extensions links. This is something that Andrew had
started and which I have taken further. I have done this in
sub-directories created by applSetupDir too. The result is that the
executable path can have relative entries (base/bin/`arch` etc)
before any absolute ones and thus you always pick up the correct
versions of EPICS stuff. This may be controversial (I know that R3.11
had something similar implemented via hidden files and this was taken
out...).
5. Secondly, the default.dctsdr etc links are in a sub-directory called
data. As will be seen, all source files are in a src tree and the
Makefiles in this tree install to various sub-directories of the
application directory (there is support for installing elsewhere for
reasons of version management). The install directories are the
standard EPICS ones (bin, lib, include, man, doc) plus a new one
(data: for data files, assumed architecture-independent) plus there
needs to be ascii (see later) but I haven't added that yet.
6. I also modified applSetupDir with a "-keck" option (and also a
"-getrel" option which causes it to invoke getrel too), which causes
it to add some more links and populate a skeleton src tree. It can
now safely be executed as many times as you like and will only create
files which don't exist (necessary if you are going to execute it
each time you do a cvs checkout, as is the intention). Doing
"applSetupDir -keck" on the above gives (with some stuff omitted for
brevity):
ls -alR
total 14
drwxr-xr-x 4 512 May 31 12:41 .
-rw-r--r-- 1 36 May 31 12:40 .setupAsEPICS
-rw-r--r-- 1 1323 May 31 12:41 CONFIG_APPLIC
-rw-r--r-- 1 119 May 31 12:41 Makefile
drwxr-xr-x 9 512 May 31 12:41 src
lrwxrwxrwx 1 35 May 31 12:40 templates -> extensions/src/saekeck/templates
data: (unchanged from before)
src:
total 13
drwxr-xr-x 9 512 May 31 12:41 .
drwxr-xr-x 4 512 May 31 12:41 ..
-rw-r--r-- 1 139 May 31 12:41 Makefile
drwxr-xr-x 2 512 May 31 12:41 alh
drwxr-xr-x 5 512 May 31 12:41 ar
drwxr-xr-x 4 512 May 31 12:41 ascii
lrwxrwxrwx 1 7 May 31 12:41 base -> ../base
drwxr-xr-x 2 512 May 31 12:41 capfast
lrwxrwxrwx 1 9 May 31 12:41 config -> ../config
drwxr-xr-x 2 512 May 31 12:41 db
drwxr-xr-x 2 512 May 31 12:41 dl
lrwxrwxrwx 1 13 May 31 12:41 extensions -> ../extensions
drwxr-xr-x 2 512 May 31 12:41 misc
src/alh:
total 6
drwxr-xr-x 2 512 May 31 12:41 .
drwxr-xr-x 9 512 May 31 12:41 ..
-rw-r--r-- 1 120 May 31 12:41 Makefile
src/ar: (like alh except creates arChan etc dirs)
src/ascii: (make in here does makesdr; cf base/src/ascii)
total 9
lrwxrwxrwx 1 34 May 31 12:41 Makefile -> ../../templates/src/ascii/Makefile
lrwxrwxrwx 1 39 May 31 12:41 Makefile.Unix -> ../../templates/src/ascii/Makefile.Unix
drwxr-xr-x 2 512 May 31 12:41 cat_ascii
drwxr-xr-x 2 512 May 31 12:41 replace_ascii
src/ascii/cat_ascii: (initially empty)
src/ascii/replace_ascii: (initially empty)
src/capfast: (like old gdct directory)
total 8
-rw-r--r-- 1 124 May 31 12:41 Makefile
-rw-r--r-- 1 272 May 31 12:41 Makefile.Unix
lrwxrwxrwx 1 31 May 31 12:41 edb.def -> extensions/src/e2sr/lib/edb.def
src/db: (like alh; hopefully not used!)
total 9
-rw-r--r-- 1 267 May 31 12:41 Makefile.Unix
lrwxrwxrwx 1 25 May 31 12:41 default.dctsdr -> ../../data/default.dctsdr
lrwxrwxrwx 1 25 May 31 12:41 default.sdrSum -> ../../data/default.sdrSum
src/dl:
total 8
lrwxrwxrwx 1 35 May 31 12:41 template.adl -> ../../templates/src/dl/template.adl
lrwxrwxrwx 1 34 May 31 12:41 template.dl -> ../../templates/src/dl/template.dl
src/misc:
total 10
-rw-r--r-- 1 121 May 31 12:41 Makefile
-rw-r--r-- 1 644 May 31 12:41 Makefile.Unix
-rw-r--r-- 1 340 May 31 12:41 Makefile.Vx
-rw-r--r-- 1 0 May 26 17:17 resource.def
-rw-r--r-- 1 1147 May 30 11:13 startup.vws ("VxWorks Shell")
7. I haven't done all the make rules yet, but have done those in capfast
(to generate ASCII .db files from .sch files using e2sr) and ascii (a
wrap around makesdr similar to the way base/src/ascii does it).
There's a rule to generate xxx from xxx.vws including sed'ing :arch:
and :appl: as appropriate.
8. I've already gone on too long, but just a word on the Makefiles,
release management and so on. I have defined a new CONFIG_APPLIC
which is included by all the Makefiles (cf CONFIG_BASE and
CONFIG_EXTENSIONS). This overrides some stuff and also includes (if
it exists) a CONFIG_APPLIC file from the application directory which
controls where files are installed, where external application
includes and libraries are taken from, which target architectures
should be built etc. I have added some stuff to RULES.*, but nothing
that should be a problem (practical or intellectual) for the main
EPICS build. Here's the template src/misc/Makefile.Unix. It's pretty
like a typical such file in one of the extensions/src/xxx
directories.
# will/src/misc $Id$
# $Log$
EPICS = ../../..
include Target.include
include $(EPICS)/config/CONFIG_APPLIC
# External libraries on which this directory is dependent
DEPLIBS =
# User compiler and loader flags (., .., local installation, application-wide,
# EPICS base and EPICS extensions directories are automatically searched)
USR_CFLAGS =
USR_INCLUDES =
USR_LDFLAGS =
USR_LDLIBS =
# Names of C source files (no extensions)
NAMES =
SRCS.c = $(NAMES:%=%.c)
OBJS = $(NAMES:%=%.o)
# Standard macros for files which are to be built and installed
PROD =
LIBNAME =
INC =
MAN1 =
DOCS =
SCRIPTS =
DATA = resource.def
include $(EPICS)/config/RULES.Unix
Still to do
1. It's working but not quite done. The biggest thing that I still need
to do is to sort out how to handle ascii files from multiple
application directories. Doing "make install" in src/ascii should
install the files in the cat_ascii and replace_ascii directories so
that they can be referenced by other application directories (the
idea is that other application directories should not directly
reference src trees, only installed files). Given that there can be
name conflicts (everyone might append to choiceGbl.ascii for
example), the application directory name must be part of the
installation directory. For application directory "fred" I propose
installing the files to ascii/fred/add (cf cat_ascii), ascii/fred/rep
(cf replace_ascii) and ascii/fred/sub (patterns to be _removed_ from
files rather than added; won't get implemented unless it's needed).
Then the application directory CONFIG_APPLIC file will be able to
contain a list of application directories from which "make install"
in src/ascii should take and concatenate (or whatever) the ascii
files.
2. The above scheme will fit our requirements, where I don't want to put
our private application-specific records and device support into
EPICS base. As a rule of thumb I want EPICS base only to contain the
sort of local stuff which should be submitted to the community for a
future release.
3. There's some more tidying up of the template Makefiles, plus
applSetupDir has become chock full of duplicated code. It would be
better to drive it entirely via the contents of the template
directory (which is now a tree); or even to make the Makefiles create
default trees automatically?
4. There are some more tools to write to do with handling release
directories. I hardly mentioned this, but I think the necessary
hooks are in there and working.
5. It needs documenting. I apologise for this long initial message.
Subsequent discussion can involve a smaller group.
6. I will have some minor comments on the EPICS config files and so on
... but have had very little trouble, and the fact that I have had
to change so little in order to get this application stuff working is
a testament to their good design. I really like GNU make (although I
_did_ like .KEEP_STATE:) ... and I _love_ CVS!
----------------- William Lupton ([email protected]) -----------------
Home: PO Box 7135, Work: W. M. Keck Observatory, PO Box 220,
Kamuela, HI 96743, USA Kamuela, HI 96743, USA
(808) 885 3475 (808) 885 7887, (808) 885 4464 (fax)
- Re: application directories and CVS, GNU make etc Johnny Tang
Re: MCG AboveBoard Newsletter Vol.2 Num.5/ 4. Mitsubishi PLCC EEPROM Availability winans
Re: application directories and CVS, GNU make etc Nick Rees
<1995>
2025
<1995>
2025
