1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Early results of Using the Channel Access Nameserver..
From: Matthias Clausen DESY -MKS-2/KRYK- <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Fri, 5 Sep 1997 8:25:56 +0200 (MET-DST)
Is this the result of the discussion in Vancouver?
Namely: is this nameserver based on the port. ca-server and Jeffs add-ons to CA?
If yes:
- you probably use the EPICS_CA_ADDR_LIST to find the nameserver!?
- do you also use another EPICS_CA_SERVER_PORT?
- how do you configure the nameserver?
  - does it broadcast itself (at least once)
  - is it based on static files?
- ... and does a ca_search fall through to broadcast if the nameserver is not found?
Matthias
Prev: Re: oms58 record support Graham Waters
Next: EuroEPICS Agenda Bob Dalesio
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Early results of Using the Channel Access Nameserver at TJNAF David A . Bryan
Next: RE: Early results of Using the Channel Access Nameserver.. Jeff Hill
