1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Early results of Using the Channel Access Nameserver at TJNAF
To: [email protected]
Date: Thu, 04 Sep 1997 8:33:18 EDT
--- Begin Message ---
In terms of reducing the load on IOCs due to search requests, it has been
observed that when a typical BURT job of a few thousand channels is run using
the old BURT, a drop in available CPU power of 5-8% can be clearly observered
on all IOCs, while no noticeable drop is visible when the same BURT job is run
using the new BURT (Note however, this on IOCs that do not have the channels
in the BURT job.  Needless to say after locating the channels, the ca_get()
operations are still executed on the appropriate IOC..) To view a StripTool
plot of the load on 4 sample IOCs at TJNAF when such a test was run, visit:
http://www.jlab.org/~bryan/burt_res.html
Please feel free to contact me if you have questions.
	--David Bryan
David A. Bryan - Computer Sciences Corporation
Thomas Jefferson National Accelerator Facility
12000 Jefferson Ave., Newport News, VA 23606
Office: CEBAF Center A213
Voice : 757-269-7073                        Page: 757-680-9484
email : [email protected]                     Fax : 757-269-5024
--- End Message ---
Prev: Re: oms58 record support Benjamin Franksen
Next: Re: oms58 record support Marty Kraimer
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: oms58 record support Graham Waters
Next: Re: Early results of Using the Channel Access Nameserver.. Matthias Clausen DESY -MKS-2/KRYK-
