1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: oms58 record support
To: [email protected]
Date: Thu, 04 Sep 1997 13:22:34 -0700
< Graham Waters wrote:
> I recently build the motor record and oms58 support for R3.13.xxx.
> I can only get it to initialize properly ( I think) by explicitly
> calling motor_init() (defined in drvOms58.c) after oms58Setup() in my
> startup script.
> If I don't do this it is never called and I get the following message:
> Illegal field value PV: "my record instance name" devOms58 (init_record)
> card does not exit!
> Am I must be missing an entry table somewhere?
> Graham.
Thanks to all who responded.
The record is up and running.
| Graham Waters, Control System Eng          Internet: [email protected]
| TRIUMF --- University of British Columbia,	phone: (604)-222-1047   |
| Vancouver, BC, Canada                           Fax: (604)-222-7307
| http://sunset.triumf.ca/homepage/graham01.html
oms58 record support Graham Waters
Re: oms58 record support Marty Kraimer
Prev: Re: oms58 record support Marty Kraimer
Next: Re: Early results of Using the Channel Access Nameserver.. Matthias Clausen DESY -MKS-2/KRYK-
Index: 1994  1995  1996  <1997>  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Early results of Using the Channel Access Nameserver at TJNAF David A . Bryan
