1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICs on PC
To: "Derrick C. Mancini" <[email protected]>
Cc: [email protected]
Date: Thu, 02 Oct 1997 10:00:24 +0100
Mr. Mancini, hello tech-talk:
Derrick C. Mancini ([email protected]) sent me this question
which might be of general interest.
If not please ignore it...
>I am thinking about implementing IOC on a PC box with need to also support
a new
>ISA card.
>Your method describes doing so using Windows Tornado.  Is there any reason why
>you couldn't use the Solaris based VxWorks development system if you purchased
>the x86 target tools and license?
I don't know anyone who has tried that but it should not pose any problem.
On any platform you should be able to compile EPICS/base just by
        launching a shell
        "cd <EPICS base>"
        "gnumake"
as soon as you have
* Tornado for the host/target combination that you need,
* GNUmake and a simple UNIX-style shell available.
Note that even on the PC a simple UNIX-style shell is
still necessary. On UNIX it's already there, of course.
Our motivation was to do it all on the PC because
* PCs are much cheaper than UNIX workstations,
* Windriver was soon selling more than 50% of its host licenses
  for PC as soon as PC-Tornado came out,
  so EPICS should be able to use it.
But we didn't break the build on workstations,
it's still an option  :-)
>Also, when developing, you do so with two machines.
Yes, as usual with EPICS developement:
You used to have a UNIX host and a VME IOC,
now you can also use a PC host and a PC IOC.
>But is there anything to prevent one from actually using the same machine
for host
>developer and target, by say using the reboot choice option, so that you
would >compile
>under Windows, but the binary into correct location, reboot under VxWorks
and run?
That sure can be done (in fact I have done that).
Even more:
People at DESY have tried some version of Tornado/VxWorks
where VxWorks is not a separate _OS_ for the PC but a _task_
running unter Windows95,
so then your PC can be both 'host' and 'IOC' at the same time.
However, I cannot remember the name of that VxWorks version.
I think it was not an original Windriver product and you loose
some real-time specs because VxWorks is just one task
among other Windows95 task.
Hope this helps,
-Kay
Re: EPICs on PC Gabor Csuka
Prev: Problem with VMS Multinet 4.0RevB - Channel Access Connects saa
Next: Re: EPICs on PC Gabor Csuka
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
