1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Serial comms solution
To: [email protected]
Cc: [email protected]
Date: Wed, 22 Oct 1997 17:17:35 -1000
GreenSpring OctalUart IP Module Support
TCS IV uses the GreenSpring OctalUart family of Industry Pack modules
to communicate with a number of RS-232, RS-422, and RS-485
devices. These IP modules are mounted on a Greenpring VIPC-610 VMEbus
carrier board.
The driver uses drvIpac for configuration of the carrier board plus
access routines for the SCC2698 octalUart used in the IP modules. The
driver is implemented as a standard vxWorks terminal driver making
used of the tyLib() system library.
See: http://www.cfht.hawaii.edu/~tcs/tcsiv/tygsoctal.html
Peregrine M. McGehee
Telescope Control Systems Group
Canada-France-Hawaii Telescope Corporation
Prev: Re: List of Record Support not in base. Steve Lewis
Next: archiving with sdds Frederic MICHAUD
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Serial comms solution Peregrine McGehee
Next: Problem with VMS Multinet 4.0RevB - Channel Access Connects saa
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
