1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Flash programming on 162
To: "Garrett D. Rinehart" <[email protected]>
Cc: [email protected]
Date: Wed, 14 Oct 1998 10:25:04 -0500
Garrett,
re.. When I type "pf 0" I get "f0"
It sounds like you have the parity or bit count wrong
on the serial connection to the 162. Make sure you
the workstations serial port is set for 8bits, no parity.
re.. switching to 4800
If you have a 162-5xx board this should not be necessary.
It can handle a 9600 baud download.
re..isn't there a way to dump it from one 162 to another?
> Till Straumann <[email protected]> wrote...
> You want to program the flash memory of one or multiple mvme152-532FX
> cards? Here is how you can use the VME bus to make copies of an already
> written board's flash memory:
> http://www-csr.bessy.de/control/Hard/IOC/bootpromDoc.html . This saves a
> lot of time if you have to write multiple boards, but because it's so
> easy, you might do it the fast way for any number of  cards.
Joe Sullivan
APS/XFD
Flash programming on 162 Garrett D. Rinehart
Prev: Flash programming on 162 Garrett D. Rinehart
Next: Re: Flash programming on 162 Graham Waters
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
