1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Flash programming on 162
To: [email protected]
Date: Wed, 14 Oct 1998 10:06:57 -0500
Hi everyone.
I've got a new mv162 that needs its flash memory
programmed for vxWorks boot. I've tried to follow
John's instuctions from a couple of years ago, but I
can't even get started.
In his instructions (can be found with list server
archive search from EPICS page at APS), he says to
connect at 9600 bps, then switch it to 4800 with the
command "pf 0". When I type "pf 0" I get "f0" echoed.
It doesn't seem to get the "p" or the space. For that
matter, I can hit "return" all I want and nothing ever
happens (before or after this command).
Can anyone help me get this silly thing loaded?
BTW, isn't there a way to dump it from one 162 to
another? I've got two others that had been set up (by
John) a while back. If there's a less painful way to do
this, I'm all ears.
Thanks in advance.
-- Garrett Rinehart
   Intense Pulsed Neutron Source
   Argonne National Laboratory
Re: Flash programming on 162 Joe Sullivan
Re: Flash programming on 162 Graham Waters
Re: Flash programming on 162 Ralph Lange
Prev: powerPC floating point underflow Kevin Tsubota
Next: Re: Flash programming on 162 Joe Sullivan
Index: 1994  1995  1996  1997  <1998>  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: powerPC floating point underflow Jeff Hill
