Dear all,
I am trying to download VxWorks and EPICS example to MV162
from SUN solaris2.7. I have seen the VxWorks boot image on the terminal. But
there is problem with EPICS.
(R) ] ]]]]]]]]]
Development
System ]]]]]]]]]]]]]]]]]]]]]]]]]]]] ]]]]]]]]]]]]]]]]]]]]]]]]]]]
VxWorks version
5.3.1 ]]]]]]]]]]]]]]]]]]]]]]]]]]
KERNEL: WIND version
2.5 ]]]]]]]]]]]]]]]]]]]]]]]]]
Copyright Wind River Systems, Inc., 1984-1997
CPU: Motorola MVME162. Processor
#0.
Memory Size: 0x400000. BSP version
1.1/5.
WDB: Ready.
Executing startup script
/export/home/zheng/epicsTest/iocBoot/iocexample/st.cmd ... # Example vxWorks
startup file
# Following must be added for many board support
packages #cd <full path to target bin directory>
cd /export/home/zheng/epicsTest/bin/mv162 syntax
error
Done executing startup script
In /usr/local/tornado101/target/config/mv162/config.h, I
define as follow:
#define DEFAULT_BOOT_LINE
\ "ei(0,0)COSUN-01:/usr/local/tornado101/target/config/mv162/vxWorks
h=159.226.222.79 \ e=159.226.222.85 u=guest pw=control tn=MV162 f=0
\ s=/export/home/zheng/epicsTest/iocBoot/iocexample/st.cmd"
In <VxWorksBoot>, the parameters is :
boot
device : ei processor
number : 0 host
name :
COSUN-01 file
name :
/usr/local/tornado101/target/config/mv162/vxWorks inet on ethernet (e) :
159.226.222.85 inet on backplane (b): host inet
(h) : 159.226.222.79 gateway inet
(g) : user
(u) :
guest ftp password (pw) (blank = use rsh): control flags
(f) : 0x0
target name (tn) : MV162 startup script
(s) : /export/home/zheng/epicsTest/iocBoot/iocexample/st.cmd
other (o)
The .../st.cmd is:
# Example vxWorks startup file
cd /export/home/zheng/epicsTest/bin/mv162 ld <
iocCore ld < seq ld < exampleLib
#cd
startup dbLoadDatabase("../../dbd/exampleApp.dbd") dbLoadRecords("../../db/dbExample1.db","user=zhenglf") dbLoadRecords("../../db/dbExample2.db")
iocInit seq &snctest
Could somebody tell me what I made the mistakes and how to
solve them?
Thanks in advance.
Lifang Zheng
