>cd /export/home/zheng/epicsTest/bin/mv162
>syntax error
It's cd "/export/home/zheng/epicsTest/bin/mv162"
Is it ok now or is there another problem?
Francoise Gougnaud.
>From: "Zheng Lifang" <[email protected]>
>To: "EPICS tech-talk" <[email protected]>
>Subject: problems with downloading VxWorks and Epics
>Date: Thu, 9 Sep 1999 16:03:08 +0800
>Mime-Version: 1.0
>X-Priority: 3
>X-Msmail-Priority: Normal
>X-Mimeole: Produced By Microsoft MimeOLE V5.00.2014.211
>Dear all,
>I am trying to download VxWorks and EPICS example to MV162 from SUN solaris2.7.
I have seen the VxWorks boot image on the terminal. But there is problem with
EPICS.
> ]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
> ]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
> ]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks version 5.3.1
> ]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.5
> ]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-1997
> CPU: Motorola MVME162. Processor #0.
> Memory Size: 0x400000. BSP version 1.1/5.
> WDB: Ready.
>Executing startup script /export/home/zheng/epicsTest/iocBoot/iocexample/st.cmd
># Example vxWorks startup file
># Following must be added for many board support packages
>#cd <full path to target bin directory>
>syntax error
>Done executing startup script
>In /usr/local/tornado101/target/config/mv162/config.h, I define as follow:
>#define DEFAULT_BOOT_LINE \
>"ei(0,0)COSUN-01:/usr/local/tornado101/target/config/mv162/vxWorks
h=159.226.222.79 \
> e=159.226.222.85 u=guest pw=control tn=MV162 f=0 \
> s=/export/home/zheng/epicsTest/iocBoot/iocexample/st.cmd"
>In <VxWorksBoot>, the parameters is :
>boot device : ei
>processor number : 0
>host name : COSUN-01
>file name : /usr/local/tornado101/target/config/mv162/vxWorks
>inet on ethernet (e) : 159.226.222.85
>inet on backplane (b):
>host inet (h) : 159.226.222.79
>gateway inet (g) :
>user (u) : guest
>ftp password (pw) (blank = use rsh): control
>flags (f) : 0x0
>target name (tn) : MV162
>startup script (s) : /export/home/zheng/epicsTest/iocBoot/iocexample/st.cmd
>other (o)
>The .../st.cmd is:
>ld < iocCore
>ld < seq
>ld < exampleLib
>#cd startup
>dbLoadDatabase("../../dbd/exampleApp.dbd")
>dbLoadRecords("../../db/dbExample1.db","user=zhenglf")
>dbLoadRecords("../../db/dbExample2.db")
>iocInit
>seq &snctest
>Could somebody tell me what I made the mistakes and how to solve them?
>Thanks in advance.
>Lifang Zheng
problems with downloading VxWorks and Epics Zheng Lifang
Re: problems with downloading VxWorks and Epics Ralph Lange
<1999>
2025
Problems with CA in a WAN environment Stefan Hippler
<1999>
2025
