1994  1995  1996  1997  1998  1999  2000  <2001>  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <2001>  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: VMIC 2510B board
To: "Mythili Srinivasan" <[email protected]>, <[email protected]>
Date: Mon, 22 Jan 2001 12:56:34 -0700
>   I'm trying to develop a driver for VMIVME 2510B,64channel digital i/o
> board.I found driver of vmivme 2534 board is somewhat similar to 2510B,so
> tailored that for 2510B.But,now I'm facing problems w.r.t. handling
> 64bit data,as the compiler doesn't support 'long long'.
>   Can anybody suggest me some way to handle this? Actually I tried with a
> structure containing two 32bit words to accomplish the goal.But,throught
> the source code of EPICS,wherever RVAL,MASK etc., are being used,I'm in
> need of changing the dependents appropriately.
>   Thanks in Advance.
I would create a structure containing 32 bit unsigned integer "volatile uint32_t"
fields that overlay your device. You could use your device specific addressing to
locate the proper word within your structure. The situation will be similar for
MBBI / MBBO records with the constraint that you will not be able to support bit
field widths greater than 32 bits, nor bit fields that cross 32 bit word boundaries
in your device. The 32 bit boundary constraints is built into the design of the
mbbi/mbbo records interface between itself and device support and could be overcome
only by joining two mbbi records with a calculation record (or splitting a soft mbbo
record with two calculation records). You could also write a specialized record.
Jeff
VMIC 2510B board Mythili Srinivasan
Prev: Re: compiler errors Bill Brown
Next: VMIC 2510B board Mythili Srinivasan
Index: 1994  1995  1996  1997  1998  1999  2000  <2001>  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: VMIC 2510B board Mythili Srinivasan
Next: Next EPICS Collaboration Meeting Bob Dalesio
