Carl Lionberger wrote:
> For some time there were fields for specifying the one severity, zero
> severity, and change-of-state severity for each bit (yes, 48 fields) in
> mbbiDirectRecord.dbd; as far as I know there was never any code for
> dealing with these fields in mbbiDirectRecord.c and now in 3.13.3 they
> have been removed from the dbd file.
> Do people think implementing these fields would be a good idea? Did
> someone try it and decide it wasn't practical? I'm working on the byte
> widget for edm and could support using them, and I could put them in the
> record too if the whole idea doesn't seem unreasonable. I guess a ca
> client would have to monitor each bit individually rather than just
> monitor VAL for the severity to get across on a bitwise basis?
I think the usual solution is to have soft bi records with their INP
link (with CPP attribute) pointing to each of the single bits of the
mbbiDirect.
With your proposal one could get rid of these bi records. On the other
hand, one looses the ability to give each bit a separate name,
description, etc.
Ben
- bitwise severities on mbbiDirect Carl Lionberger
Support for HP8656B Vitaliy Vziskin
Re: bitwise severities on mbbiDirect Brian McAllister
<2001>
<2001>
